Thread: Liquidator tank
    Aug 2013
    Phoenix AZ
    5
    Liquidator tank
    I bought a liquidator a little over a year ago and the tank is leaking at the bottom. Any recommendations on where to get a replacement tank or what to use to build another tank? Haven't drained it yet to find the crack. Dry on the sides.
    12k gallon, AG, pebble, sand filter, 1hp single speed pump, G3 Barracuda, Liquidator, TF 100 test kit
    Ellington, CT
    262
    Re: Liquidator tank
    Call Hasa, it may be under warranty.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Aug 2013
    Phoenix AZ
    5
    Re: Liquidator tank
    Tanks not covered. I slapped a epoxy repair on for now and will see how it holds up. I found a rubbermaid 12.5 gallon garbage bin at home depot I will use if my repair doesn't hold up very long. Hopefully the chlorine won't eat the rubbermaid bin
