Page 1 of 7 1234 ... LastLast
Results 1 to 20 of 129
Thread: Cynauric
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Cynauric
    It's been a month now since I put any chlorine in the pool and the Cyanuric Acid is still through the roof. It's been raining here in Northern California quite a bit this year so I've actually had to drain water at times. Still, the number is anywhere from 100-200 plus depending on who's measuring. I was at Leslie's yesterday for a two week check and of course, get inconsistent readings as usual. They're trying to sell me the "Bio-Active" for $50 but I'm not convinced that does anything other than add to the problem. Now the problem is, that the water looks fantastic, always had. It's the numbers that confuse things. I test every day and also bought the recommended Taylor Test kit that I've been using as well. I don't want to arbitrary drain any more water because of the drought so I'm asking, can I just ride this out and monitor until the chlorine level and Cyanuric levels drop as long as everything "looks" okay? Although I have a full bucket of tabs from Leslie's I don't plan on using them. I have liquid Chlorine, bleach on the ready and will be buying some baking soda pretty soon. Should I "shock" this water now? I have Leslie's "Powder Plus" which does not add Cyanuric, again, a full box. I'd appreciate the thoughts from the community as I'm trying, I'm really trying. Thanks.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    38,524
    Re: Cynauric
    Please post up a full set of test results from your test kit.
    We never randomly "shock" out pools. You have no reason. And Powder Plus while is does not add CYA, it does add Calcium (CH) which can get too high and require water replacement as well.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,643
    Re: Cynauric
    Any form of "shock" or "dry" chlorine (puck or powder) adds something to the water with the FC. Some it is CYA, others it is calcium (CH).
    Liquid bleach/chlorine is your best bet.
    I will be looking for your full set to tests to see what is what with your water.
    Kim
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cynauric
    Cyanuric acid isn't going to drop on its own on any kind of reasonable timeline. Maybe over a year or two you might see some decline.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Cynauric
    I'll do a complete test tomorrow and post. Thanks for your help with this.
    30,432
    Re: Cynauric
    The complete results are certainly needed. Where do you keep your Free Chlorine? 2 ppm? 6 ppm? 15 ppm?
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Cynauric
    Good question and I don't know. Where should I have it?
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Cynauric
    Do you irrigate your property at all? Any landscaping or lawn to water?
    If so, then turn off your irrigation system and use your pool water to irrigate (once the FC comes down a bit). It's not the best water to use for irrigation purposes but you can use that in lieu of any irrigation water you might use and then take that allotment and use it for pool fill. You can buy a cheap garden hose flow meter to carefully track how much water you use from the pool and then add that much back. Over time, you will slowly reduce your CYA. If you get rains, allow your pool to overfly if that's possible. Better yet, drain some your pool BEFORE it rains and let the rains add back the makeup water, that will reduce the dilution effect.
    Any commercial RO providers in your area? Costs about $300-$500 to RO a filter a pool and you typically need to add back about 15% of the pool volume due to filtration losses.
    Matt
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Cynauric
    Okay, here are my numbers this morning.
    FC=4.5
    PH=7.4
    ALK=110
    CYA is 100 plus
    Comments/suggestions appreciated. Thanks.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Cynauric
    My first thought is to ask if you plan on following TFP methods or continue visiting the pool store? Our methods are different and attempting to follow both just leads to confusion.
    Your FC is way too low. When my CYA was in the 250 range I kept my FC around 19.
    When Bioactive first came to the market several members here tested it in fairly controlled tests, testing and reporting results daily, some over several weeks. None of the controlled tests reported any significant drop in CYA thus it is not a product we generally recommend.
    It took me almost a year to get my CYA under control. I have a very high water table in my area so,a,hard drain and refill was out of the question. I rigged up a hose from one of my gutter downspouts to harvest rainwater as well as several smaller drains and refills.
    Some reading in Pool School will give you the back story on my we recommend what we do and why it differs from the advice given in most pool,stores.
    Support the site
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Cynauric
    I might visit the store from time to time but am committed to following TFP methods as much as possible. How should I get my FC up? Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Cynauric
    Use the dilution method to get a better CYA value than 100+. Step 9 Then enter that number in poolmath and it will tell you the FC target value for that CYA. Bleach or pool chlorine or "liquid shock" is what you need to add. It's all the same chemical, just different strengths. Pool School - How to Chlorinate Your Pool
    Jun 2014
    15,255
    Re: Cynauric
    Quickest, easiest way to increase is simply regular bleach. Generic is fine, but make sure it's just regular. None of that scented or splashless stuff. Use the Poolmath calculator to judge your FC target and it works great.
    May 2014
    Franklin, NC
    9,197
    Re: Cynauric
    Yup, most of us use plain generic bleach for our chlorine needs. Remember, chlorine is a consumable item and needs to be added regularly, like daily.
    Automation is available with salt water chlorine generators and pumps to add liquid chlorine.
    Support the site
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Cynauric
    I did use the dilution method and the black dot was gone way below the 100 mark. I'll add some bleach to it now and keep on monitoring/testing. Thanks.
    What measurement device (plastic cup?) do you use to add bleach? Pretty much daily? If you were gone for a couple of weeks what would you do. Float a tablet? Thanks.
    May 2014
    Franklin, NC
    9,197
    Re: Cynauric
    O
    Quote Originally Posted by Frankhugus View Post
    I have a Staenner Pump to,add bleach automatically, but before I just free poured from the bottle,without exact measurement. I was using about 1/2 bottle per day
    Remember, tabs add more cyurnatic acid to the pool as each tab is almost half CYA. Automated methods work better for vacations if possible.
    Support the site
    38,524
    Re: Cynauric
    Sounds like your CYA is well above 200ppm if you did the dilution test and it still showed more than 100 on the vial. Mine was up around 300ppm when I took over from a pool company.
    I would highly recommend starting to replace water to drop the CYA before your pool actually does develop a noticeable problem. Even not seeing algae, with very high CYA and low FC means your pool is not properly sanitized and will not kill pathogens in a timely fashion, which puts swimmers at risk of person to person disease transmission.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Cynauric
    I have been draining sizable amounts as the rain has increased but it still remains high. Hard to believe how fast CYA went up. I just can't bring myself to arbitrarily drain given the drought and am watching it daily. Thanks.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Cyanuric-Ongoing
    Yesterday I drained 2.0 hours at max speed on Intellipro pump. That's about 4". I refilled back to the 4" plus 2" more. Here are my readings as of right now.
    FC=8ppm
    CC=0
    ph=7.5
    Alk=90
    Cyanuric-somewhere between 150-180
    I still have not added any chlorine in over a month and have no floater either. I have bleach, baking soda etc. standing by but have no reason to use any of it yet. The water continues to look fantastic. Your thoughts and recommendations please. Thanks. (heating up here and no rain in sight)
  20. Back To Top    #20
    Jun 2014
    15,255
    Re: Cyanuric-Ongoing
    As we know from the Chlorine/CYA Chart, your current FC of 8 is designed for someone with a CYA at/about 70 ppm for a non-SWG pool. Since the FC target for a CYA of 100 is 12, it would stand to reason that the "target FC for someone around 150 would probably be more around 16-18 - the minimum might be around 10-11. I would suspect that you're rolling the dice with that FC/CYA ratio, and the warmer it gets (with more direct UV), the harder it will be for that FC to keep algae away. Let's see what others have to say.
