Thread: Pentair SD80 valve part number
    I have an SD 80 sand filter. The valve cracked on it and it is spraying water right where the pipe goes in from the pump. The part number says 272526 but below it has some more numbers that include 262506. When I search the internet I seem to be able to find the 262506 but not the 272526. Does anybody know the difference (or interchange possibility)? Has anybody tried to epoxy one of these valves?
    37000 gallon inground vinyl
    intelliflo 11018
    Pentair 80 sand filter
    3/4 booster with polaris 260
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pentair SD80 valve part number
    Is it a Multiport Valve You're talking about? I would think another of the same pipe size would work if it is.
    Essential Links:
