Page 1 of 4 1234 LastLast
Results 1 to 20 of 64
Thread: Jandy Nicheless LED lights
    Feb 2016
    Tallahasse, Florida
    31
    Jandy Pro Series Nicheless Watercolors LED Light JLU4C20W150 - 20 Watt - 150 Foot Cord
    Has anyone had experience with these. I just purchased 3 to install in my existing rectangle 18x36 vinyl lined pool. Any thoughts or install advice would be appreciated.
    18x36 vinyl liner. Built in 1978. Currently under construction.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    Re: Jandy Nicheless LED lights
    I feel that nicheless LEDS are the direction all pool lights are headed and regret not installing more of these lights in my pool. The traditional style lights just look old fashioned.
    Installation is very straightforward, what are you looking for help with?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jun 2015
    Mandeville, LA
    109
    No experience yet but I have three of them installed in my new build. This is the only light my builder uses anymore. Should be able to see them in action in a week or so as soon as my plaster is done.
    Completed April 2016: 22x36 3.5-5.5-4 Inground, 17,500 gallons, Aquapure SWG, Jandy 2hp Variable Speed, Jandy 460 Cartridge Filter, Polaris 280, Aqualink PDA4, Jandy Nichless LED lights, Diamondbrite color Steel Blue, Noche Travertine Coping & Deck
    Feb 2016
    Tallahasse, Florida
    31
    Was curious about placement and how much light the various models/watts give off. I planning to do a 20w at the steps and a 30w in the shallow and a 30w in the deep.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    You'll likely be disappointed with the amount of light. I'd double what you are planning.
    -Brian-
    POOL BUILD
    Feb 2016
    Tallahasse, Florida
    31
    That stinks because they aren't cheap!
    Feb 2016
    Tallahasse, Florida
    31
    Any pics?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    The closest part is the shallow area with 3 globrites (basically the same style light but made by Pentair). I have 2 full size lights in the pool.
    -Brian-
    POOL BUILD
    Feb 2016
    Tallahasse, Florida
    31
    Thanks for the pic. That kind of gives me an idea on placement to get the maximum coverage with what I've purchased. I wasn't looking for the flood light effect. If it will just offer some type of ambient light to give the water a glow at night I'll be satisfied
    Nov 2015
    Woodland Hills, CA
    176
    Quote Originally Posted by bdavis466 View Post
    I feel that this is the direction all pool lights are headed and regret not installing more of these lights in my pool. The traditional style lights just look old fashioned.
    I just finished a 150K square foot commercial remodel on 4 floors. We did all LED lighting everywhere: 2x2 and 2x4's in the ceiling, accent lights, down lights - everything. There is not a light bulb in the place, everything is a diode hooked up to a wireless control system and every light in the place is dimmed to 60% output. Its amazing not only for the energy savings - but the lack of flicker and the color rendering is fantastic.
    OP: for reference, my pool is only 12x30 and I did 3 Jandy 20w in the pool and one in the 6x6 spa.
    O/B Woodland Hills, CA : O/B12x30 inground with 6x6 10-jet spa, 10,500gal, 6' Baja deck, 42" spillway, All Jandy: 400k heater, 2.7 HP VS pump, 1.5HP booster spa pump, SWG, Intellelink controls, (4) LED lights, cartridge filter and BlueSquareQ360 infloor cleaning system, Eclipse drain, glass tiles, Zanzibar white pebble finish. Broke ground 2/18/2016, completed 8/16/2016. TFT 100 kit.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    I was speaking more of the nicheless LEDs as opposed to the conventional LED pool lights. There is no reason to install any light that isn't an LED other than the initial expense. Those troffers you mentioned can get very expensive.
    -Brian-
    POOL BUILD
    Feb 2016
    Tallahasse, Florida
    31
    Frank Do you have any pics of your pool illuminated at night? Would like as many references as possible
    Nov 2015
    Woodland Hills, CA
    176
    Sorry - no. I just shotcrete'ed last week.
    LED lay in troffers are about $100ea when you are buying in volume.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I have those lights and love them.....I have 3 along one side of the pool and 1 in the spa. I just replaced the non nicheless Jandy WaterColor LED's because they kept breaking. Jandy replaced all of mine with these under warranty. I would definitely get 3. If there isn't enough light you will regret it!
    My only advice is to make sure the lights are along the wall that face away from the house/main sitting area....
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    Nov 2015
    Ok ok
    822
    How do they attach? Power up?
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Nov 2015
    Woodland Hills, CA
    176
    I opened the box to check mine out:
    Here is the color card:
    Feb 2016
    Tallahasse, Florida
    31
    Thanks for the replies everyone!
    Lykly my understanding is they hook to a 12v transformer and can be activated by a simple switch or even something like iaqualink system. The no need for bonding/grounding was a sell for me. I didn't want to fool with that.
    Oct 2015
    Spanish Fort , Alabama
    45
    Are these the same as the SAVI pool lights ? They look the same !
    do they have a model that will work with the Pentair controllers ?
    Apr 2013
    Sacramento, CA
    2,769
    Jandy purchased Savi. Pentair has there own version
  20. Back To Top    #20
    Oct 2015
    45
    Quote Originally Posted by gwegan View Post
    savi did have the Pentair designation in their line .
