Results 1 to 7 of 7
Thread: Re: Reverse Osmosis for pool filtration?
    Mar 2015
    Jacksonville, FL
    26
    I hope I am not hijacking but I figured I'd ask here instead of starting a new thread. So building my second pool here in Florida and as well all know the calcium is hard. I realize some is needed. So is it acceptable to fill some of the pool with R/O? I was going to throw 3 hoses in the pool and have one of them connected to R/O system. If I can get the calcium even 20% lower I'd be happy as I remember how high mine was in my last house... Any comments?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey Trader, welcome to TFP!
    We actually want you to start a new thread so that we can give it the attention deserves. It will get more answers as opposed to bumping an old one.
    At that ratio it will be perfectly fine to fill the pool with it. With enough calcium in the third it could be just as fine to fill the other two thirds with RO water if it were available.
    Essential Links:
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    I'm curious as to what the calcium level is on your fill water? Straight outta the tap, y'know?
    Mar 2015
    Jacksonville, FL
    26
    Thanks Patrick.
    I was actually a member years ago but I don't know what happened as my old login and password did not work. But either way, as long as I can get on we're good.
    Thank you as well for responding to my question. I'm currently meeting with 5 builders and getting quotes. But I am contemplating just learning enough to contract it out myself. I'll start a new thread once it all begins
    David
    Quote Originally Posted by YippeeSkippy View Post
    I'm actually going to test it. I have the colorq tester (forget who made it). I'm color blind and the read out is nice. The system has it's limits though as once the FC is above 10 it's basically worthless but for testing CH it should be suffice.
    Under Construction:
    17'6 x 31' x Shotcrete. Pentair 2HP 2 Speed Pump, Glo Brite LED, Easytouch 8 w/ ICP 8, Intellichlor IC-40, 150SF Cartridge.
    Previous: Free form 14K, Shotcrete, used BBB
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    I wish we had R/O options here in the desert.
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What sort of R/O system are you planning on using?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Emini, you might find you don't have the capacity with a residential R/O unit to fill that much, but if you have a whole house softener you can also use that...just watch the gallon meter as you will likely tap that out too and unwittingly switch to raw water
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
