Results 1 to 7 of 7
Thread: pop up water valve has pinhole spray leaks
    Jul 2008
    Queen Creek, AZ
    71
    Been working on the pool getting ready for the hot weather here in Phoenix and my father told me that the water valve for the pop up system is leaking. Came by and noticed not 1 but 2 leaks spraying out of small pinholes. We just got this thing fixed last year cause of some ball issue. This pool is not even a year old yet. The valve is not under warranty since our pool company Riviera pools az (diamondback pool) went under and have to pay for all repairs. We discovered through some research that Riviera Pools AZ used Polaris for the pop up systems. Seems that Riviera pools custimized the system enough not to be warranty by Polaris. For some reason, Its very hard to find this particular part online. My questions is, can this be fixed without taking out another loan ? Do you have any idea where I can get this part ? PLEASE HELP. I noticed some of you here are in the industry. My main goal is to avoid calling a pool company to rip me off even more.
    Pool size 10,000 AG
    Pebble Tec
    Jandy Cartridge Filter
    Build in 2008
    Waterfall, pop ups
    Jun 2007
    NC
    255
    Re: pop up water valve has pinhole spray leaks
    Quote Originally Posted by gsmiley
    ...the water valve for the pop up system is leaking. Came by and noticed not 1 but 2 leaks spraying out of small pinholes...
    Those don't look like pin-hole leaks but stress fractures from the joint . Is there any vibration, side-side or up/down, going into that joint?
    Can you post a complete picture of your pump/filter configuration? That will help ID the problem and resolution.
    Terry in NC
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Maybe a pool epoxy putty/plumbers epoxy putty can get you through until you can find a replacement part?
    Jun 2007
    NC
    255
    Quote Originally Posted by frustratedpoolmom
    Darn, FPM, you are good! 8)
    Triad Region of NC
    11,969
    Quote Originally Posted by fuzzy_dba
    shucks....
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    I don't know these folks, so proceed with caution, but they have Caretaker parts: http://www.poolsinc.com/pd_clean.html.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Jul 2008
    Queen Creek, AZ
    71
    Thanks for all the replies. We had to put some PVC glue to stop the leak for now and its working. I'll have to buy the pool part ASAP, thanks for the link.
    Pool size 10,000 AG
    Pebble Tec
    Build in 2008
    Waterfall, pop ups
