Results 1 to 9 of 9
Thread: Need advice on valve replacement in close quarters
    Mar 2016
    Massachusetts
    11
    I have a handy valve with a crazy K on the bottom. It's 2" on one side and then connects to a 1.5 on the other where there is T and another valve. The connections are right up against each other a d I am looking for options that doesn't involve me replacing the entire stack.
    38,275
    Re: Need advice on valve replacement in close quarters
    Welcome to TFP!
    Please post pictures.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Also, please add your state to your location. Climate is often important in pool care. And you can add your pool info to your signature if you want. More here, Pool School - Read This Before You Post
    Mar 2016
    Massachusetts
    11
    I bought this house two years ago with the pool and have read every last page of this forum learning about it. I just updated my signature but I am in the process of switching out all the equipment since it was put in with the pool in 02 and is starting to fail. I have attached the two pictures of the plumbing issue I originally posted about.
    34x18 ~25K Gallon Inground Pool, vinyl liner (I have no idea whats under it) with 4 person inground hot tub. Just now installing Raypak 400K BTU Propane (replace 15yr old 333 Raypak), Pentaire Clean and Clear Plus Cartridge Filter 320sq/ft (replacing 250lb Hayward Sand), Pentaire VS 1.5HP (replacing Hayward 1HP Super Pump), Hayward AQR15 Salt Ionizer (replace hayward chlorinator). Nautilus pool robot. I live in New England in the woods.
    Mar 2016
    Massachusetts
    11
    Quote Originally Posted by Jkuter View Post
    Sorry this should say I have a Jandy Valve with a crack on the bottom.
    DFW, TX
    24,485
    It looks like it has already been replumbed once. Jandy valves have a 1-1/2" inside and 2" outside or 2" inside and 2-1/2" outside diameter. So that you can cut the pipe flush to the valve end and use the side that hasn't been used before. Usually they are plumbed on the inside first time and outside second time. You could do that with the valve on the right in the bottom pic. But, the valve on the left is using the outside diameter now.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Looks like the typical pool builder "compact" pad they are always so proud of where you almost always have to cut out everything to fix a single problem. I wish pool builders and new pool owners would stop thinking, smaller is better for plumbing layout.
    Mar 2016
    Massachusetts
    11
    [deleted for new thread]
    Mar 2016
    Massachusetts
    11
    Quote Originally Posted by pooldv View Post
    Ahh I get it now, take the whole section out past the T, that makes a lot of sense, I'll go for the and replace the valve and 90 on the other side. Thanks.
