Results 1 to 11 of 11
Thread: MiniMax NT 400 blower fan motor does not come on
    Mar 2016
    Orange County, California
    7
    I have one of the older Minimax NT 400 (I know its horrible) heaters. The fan was not coming on so I pulled it off and noticed the squirrel cage was rusted. I replaced the entire unit. Even after replacing the motor the fan does not kick on. The fan does feel warm to the touch. I called pentair and they had me jumper the ignition module but this did not work either.
    Any thoughts on what else it might be?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: MiniMax NT 400 blower fan motor does not come on
    Yours has the digital display on it?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mar 2016
    7
    Yes it does.
    17.5k gal. IG pebble tech pool and spa. Ecomatic 36 Salt, Pentair Minimax NT 400, Hayward DE filter, 2 2hp Whisperflow pumps, waterfall, slide, Pentair Intellitouch remote
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Yous should get an error message on the display. Do you? You also replaced the entire blower correct not just the squirrel cage?
    Paul
    Mar 2016
    7
    Yes I replaced the entire motor. I am not getting an error codes now. Prior to replacing the motor I received an E04. Now I hear the motor hum like it has power but nothing. No blower, ignite, etc.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Did the motor spin ok when you put it in? If so, usually when it hums like that it's either a frozen up motor or a bad start/run capacitor. Seeing yours is a new motor I would have to check to see that the motor is getting the correct power to it.
    Paul
    Mar 2016
    7
    Yes, it was spinning. The capacitor was new and came with the motor.
    Mar 2016
    7
    I just pulled the motor off and noticed that the flap that appears to be to prevent debree does hit the cage and when it is in the down position could block it from spinning. Is OK to bend this piece out of the way?IMG_0377.jpg
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Yes I would bend it a bit to allow the fan to spin. It should not be making any contact with the fan.
    Paul
    Mar 2016
    7
    I will give that a try this morning. Thank you for your help.
    Mar 2016
    7
    I have replaced the blower motor with a new one since it would not spin.
    The power, pressure switch lights are on. When I activate the heat there is a click and the temperature light comes on green. Then nothing.
    I jumped the f1 and f2 on the ignition module and the fan comes on and spins. Does this mean the ignition module is bad?
