Page 1 of 3 123 LastLast
Results 1 to 20 of 52
Thread: Resurface and coping question on north DFW TX
    Jan 2013
    The Colon(y), Tx
    47
    Hey guys,
    I am using a plaster company to do our reservice on our 1994 SWCG pool. We are going with the white plaster with 30% blue Quartz on their recommendation for longevity. I've researched it quite a bit and with our budget and our long-term outlook, that does make sense for us even though a pebble would be nice too.
    My question is, we are keeping the flagstone coping in place but replacing the tile. When you see the pic below, the top of the spa curvature will be covered in new flagstone. Obviously, there's no way to get it to match perfectly. With a sunbleached as my coping currently is, I was kind of thinking about using a concrete-type stain to refresh it and to make it possibly match better.
    Since this pool has been CWCG it's whole life, should I be concerned with how much salt is embedded in the pores of the stone over the last 20 years as it relates to using a stain?
    Does anyone have any thoughts on the matter? I appreciate any guidance you can share.
    Last edited by kimkats; 03-25-2016 at 07:09 PM. Reason: Mod note-Company name removed
    15k in-ground pool, plaster, Aquapure 1400 (whole new cell/cables/sensor 5/25/15), Pentaire Cartridge filter, Ruud heater(2/13), Polaris 360 pressure side cleaner (10/14), some other stuff...
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,406
    Re: Resurface and coping question on north DFW TX
    May I ask why you are removing/replacing that part of the coping? From the picture it looks to be in good shape.
    That may help us help you.
    Kim
    Jan 2013
    The Colon(y), Tx
    47
    Quote Originally Posted by kimkats View Post
    Kim
    I guess I should clarify, the coping around the pool is staying put, the tile that is on top of the pool/spa edge is getting replaced (those tiles are temporary fill for the originals that all came off) with more stone. Romo's said that if we re-tile the top, that with a SWCG they are likely to pop again, due to the embedded salt in the mastic, but the mortar used for flagstone is much more hardy in this environment.
    The current flagstone is faded, though. Which is what gave me the idea of using a stain.
    Does that make sense?
    PS: thanks for helping Kim!
    Jul 2012
    Tallahassee, FL
    30,406
    GOT ya!! Okay you want to take that pretty blue tile all the way off If you must........BUT I will tell you that MANY of the pools here in TFP have water line tile AND SWGs so....
    Why can't they use the same stuff they are going to use on the stone to hold the tile on? (This is an honest question. I don't really know about this kind of thing so asking to make sure we both understand.)
    The coping-------to ME it looks fine. I do not notice any "fading" BUT I did not see it when it was new. Do you WANT to change it? I would worry about the salt and chlorine messing up the stain more than just the "plain" flagstone. I wonder if you could do a "test" to see how a stain on stone reacts to the pool water. It would be easy to try...get a piece of flagstone and put some stain on it and put it in the water and see what happens over about the month.
    Just throwing out ideas to see if any of them help you out.
    Kim
    Jan 2013
    The Colon(y), Tx
    47
    Oh, we'll be replacing the waterline tiles, just not the horizontal ones.
    Take a look below for our choice:
    Jul 2012
    Tallahassee, FL
    30,406
    OH! I like that! You are "allowed" use those LOL! PRETTY!
    Kim
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Those tiles look very pretty! Is the pattern called Siren, by any chance? (It just looks kind of familiar.)
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Jan 2013
    The Colon(y), Tx
    47
    Exactly!!! Siren it is.
    Jan 2013
    The Colon(y), Tx
    47
    Quote Originally Posted by JamieP View Post
    Jamie,
    Can you share a pic of it so we can see it in real life?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I would just pressure wash with some mild acidic soap/cleaner before you apply the sealer.. the Prep needed should be in the sealer directions. Remember with sealers they will need to be reapplied at certain intervals and they are not cheap.. But they sure look good
    The Tile installer should be able to get a mix that will work just like the rock... if they say x works better for stone tell them to use x for your tile
    Aug 2014
    Houston tx
    2,524
    As someone who tried to match existing decking to new decking (imho it failed), I would suggest using a different material altogether so it doesn't look like you tried to match it. Maybe use the same tile or something that goes with that?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    JamieP's Avatar
    May 2011
    1,135
    Quote Originally Posted by NorthOfDallas View Post
    Jamie,
    Sorry, I wish I could help... We didn't go with that exact tile, but I had admired it when we were picking so I remembered it. The one we went with also has some variation in the color which I like, not only because I like each color, but I knew it would blend with whatever color the plaster ended up giving the water. The Siren is really pretty!
    Here is a link to a thread where they used Siren. Hopefully it gives you a good idea. You can see the tile installed on page 6, then with water in later pictures.
    New Build Largo, Florida - Page 6
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Yes, Siren = Nice.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Jan 2013
    The Colon(y), Tx
    47
    So, it's happening. However, after the beginning of demo we learned that the Siren tile is on a week or so backorder. Ah well...pics
    And an in-pool family selfie:
    Aug 2015
    Cypress
    1,679
    Lol @ family selfie. The kids look excited!
    Jul 2012
    Tallahassee, FL
    30,406
    CUTE pic! Love the selfie!
    Kim
    Jan 2013
    The Colon(y), Tx
    47
    So, our tile that we loved was on backorder and we had to find an alternative. We're very happy with the stone match, take a look.
    They are currently installing the tile, I will post pictures soon.
    Jan 2013
    The Colon(y), Tx
    47
  20. Back To Top    #20
    Feb 2016
    Houston, TX
    77
    I love your alternate tile! We just installed Siren on our build, and it is gorgeous, too!
    Water in, we're swimming! IG 18x29 gunite, 3.5-6.5 depth, 14,000 gallons approx, 1 skimmer, Hayward 4030 cartridge filter, Hayward Tristar VSP, 20 ft. raised bond beam with sprayers, 40 sq ft sunshelf with 2 bubblers, 7 ft round attached spa, Hayward 250k heater, quartz plaster, travertine coping, approx 800 sq feet acrylic deck
