Results 1 to 19 of 19
Thread: Choosing Pool Lights - ColorLogic v Intellibrite, Rope Lighting, and Other Questions
    Dec 2015
    Chattanooga, TN
    38
    I need to choose underwater pool lights and have these questions:
    1. I have read all the threads I could find on each light and there seem to be a lot of concern about the Hayward design of the ColorLogic pool lights leaking and causing premature failure. The last extensive post on this was a year ago and I wonder if anyone knows if this design problem has been corrected? And is the Intellibrite 5G considered significantly better? Any other better option?
    2. My PB put 3 lights in the contract. I am concerned that won't be enough. I was thinking of putting four lights in the pool - first in the middle of the 25 feet shallow, second in the middle of the 25 feet deep (both of these on the same side, facing them away from the side where we will normally be sitting), third under the diving board, and the fourth in the middle of the wall where it drops from the 18 inch deep sunshelf to 3 feet deep shallow.
    a. Do I need 3 on that 50 foot stretch (so 5 total of the normal size lights)?
    b. Will the ones on the side light the pool across the 25 foot width?
    c. What should I put in the middle of the sunshelf (which is the first 10 feet of the pool) as the Hayward specs say the top of the lens of the ColorLogic lights - even the Spa lights - (haven't checked Intellibrite) has to be not less than 18 inches below the waterline and pool depth is only 18 inches total. Anyone know of another light? I don't want that area to be dark at night.
    3. Has anyone found a good LED rope lighting that fits under the coping for a soft light when the big lights are off?
    4. PB specified 120 volt lights. I read the thread about 120 volt v 12 volt, though it is now marked as "old". Should I ask my PB to use 12 volt instead as the 12 volt is safer? How much increase in price should I expect?
    Thanks everyone. Making all these decisions is the most stressful thing I have done in years - and the TroubleFree community is making it tolerable.
    25 x 60 IG, 10' sunshelf, 24' sh, 26' dp; 57,600 gallons; 8' Jump Board; Hayward Equipment: 2 Sand Filters 36" Tank S360T2; 2 TriStar 5.0 HP FR Pumps SP3250EE; 2 Natural Gas Heaters H400FDN; OmniLogic; Sense & Dispense HL-CHEM; 2 SWG; pH Dispense Acid Feed System AQL-CHEM4-ACID; 2 systems work independently; Hydrazzo Plaster; TigerShark 2 Plus Commercial Robotic; 1 Spa and 3 ColorLogic lights; CoverStar automatic cover.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,820
    Re: Choosing Pool Lights - ColorLogic v Intellibrite, Rope Lighting, and Other Questi
    Three years in on our ColorLogic lights with no issues. Just one data point though. Love them.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Feb 2016
    Houston
    323
    Excellent questions. I have some of the same questions and hope the Hayward lights have been redesigned better. Lots of poor reviews on Amazon. One PB told me the 12v is $100 more.
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    Apr 2013
    Sacramento, CA
    2,769
    a. Do I need 3 on that 50 foot stretch (so 5 total of the normal size lights)? We really need a diagram but 3 LED lights in 50 feet is stretching it.
    b. Will the ones on the side light the pool across the 25 foot width? Probably depends on how much total light in pool. A diagram would help.
    c. What should I put in the middle of the sunshelf (which is the first 10 feet of the pool) as the Hayward specs say the top of the lens of the ColorLogic lights - even the Spa lights - (haven't checked Intellibrite) has to be not less than 18 inches below the waterline and pool depth is only 18 inches total. Anyone know of another light? I don't want that area to be dark at night. There are lights that can be as little as 4 inches below the surface. Look for Nicheless lights. Also the NEC generally requires all lights to be 18 inches below the surface, except lights designed to be less than that and they must be at least 4 inches below the surface. Furthermore lights in the sunshelf can be tough because they generally have to have sufficient cord wrapped around the fixture so they can be placed on the side of the pool for servicing. Thats 680.23 (B)6. But nicheless lights are covered in 680.23(D). So its arguable that they don't have to be able to have sufficent cord to place them on the side of the pool for servicing -- they have no extra cord. So while the code doesn't expressly say it a nichless light should be ok under your sunshelf. Clear as Mud?
    3. Has anyone found a good LED rope lighting that fits under the coping for a soft light when the big lights are off? Lets just say no. Low voltage LED is probably OK under the 2014 NEC if using a swim rated transformer and OUTSIDE THE POOL. Inside the pool its just not allowed. No LED rope lighting is listed for use in a pool and its use is not permitted by the NEC. There are fiber optic rope lights you can use.
    4. PB specified 120 volt lights. I read the thread about 120 volt v 12 volt, though it is now marked as "old". Should I ask my PB to use 12 volt instead as the 12 volt is safer? How much increase in price should I expect? Not really mush price difference and really I'm not aware of any studies that show one is safer than the other. 12 volt requires a Swim rated transformer
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    We went with low voltage lights around the perimeter and my sister gave me cool floating lights from Frontgate. It's a great soft look when the pool lights are overkill.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Feb 2016
    Albany/NY
    91
    I too have been looking into lights. I just talked to Hayward yesterday, I was wondering about the difference between the universal color logic lights and the color logic 4.0 lights in terms of connecting to the Omnilogic system. They said the only difference was that the universal lights will require a transformer.
    Starting Monday 4/18/16...18x39x30x14 L vinyl liner pool. All Hayward equipment: Tristar pump, 300K BTU heater, s310 sand filter, T-15 swg, Omnilogic. 2-12v universal color logic lights + 1-320 accent light on the steps, Latham gold pebble liner. Tf-100 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I know I should not muddy the waters but what fun would that be
    This is in no way NEC legal (they just do not and have not caught up with the tech) I have multiple safety features on this install and have years of knowledge in using these type systems.. I will in no way "teach or show" someone how to do this but the tech is out there and can be safe
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Casey, I think I just had a seizure looking at that video, lol
    Dec 2015
    Chattanooga, TN
    38
    b.Will the ones on the side light the pool across the 25 foot width? Probably depends on how much total light in pool. A diagram would help.
    20160327001133411.pdfIMG_4184.jpgIMG_4197.jpg[ATTACH]46013[/ATTACH
    I did a sketch for gwegan and either attached it twice or not at all! Hope it helps you advise me on whether I need to put another light on the shallow/deep wall that stretches 50 feet and shows 2 lights now. Thank you for your time.
    Any other comments on the design are welcome.
    I will start looking for a 4 inch nicheless light. I drew only one in the wall of the sunshelf. I am wondering if I shouldn't have 2 since they are smaller?
    Appreciate your help everyone. Surely love those lighted balls, Helen.
    I see I uploaded one picture upside down and I don't see the sketch, though I used the same upload button. Anyone know what I am doing wrong?
    Dec 2015
    Chattanooga, TN
    38
    I see the problem. I was trying to upload a pdf. So I have taken a picture of it on my phone to upload. it won't be great quality, but I hope you can understand it.Attachment 46016
    Dec 2015
    Chattanooga, TN
    38
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    Ha! My thoughts exactly!
    Quote Originally Posted by Helen203 View Post
    Sent from my SM-G935V using Tapatalk
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,820
    I would consider doing three full-size lights on the house side of the main pool section (50' x 25'). Then three or four nicheless lights on the sunshelf (one on the 9" section and two or three on the 18" section) all pointing towards the diving board.
    The LED's will be fine going across 25' of width so long as you have enough of them. Four wouldn't be ridiculous overkill on the one side (it's only money right?), but three should be good (except on the darkest colors). We have two over 38' length and 18' width (on the darkest color, 3 would be better - but I'm happy with 2). I am not a fan of having the big lights pointing in three different directions in the main pool area. Kind of like there's no way to get away from looking at them while swimming. You are almost always looking right into them.
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by Nectarologist View Post
    You have to love it
    Dec 2015
    Chattanooga, TN
    38
    Quote Originally Posted by bmoreswim View Post
    Thank you, bmoreswim! Your comment about not being able to get away from the light if they are on too many walls makes me wonder about having the nicheless lights on the end wall instead of the same wall as the other bigger lights. I will be swimming laps at night and I'm not sure I want to be facing the light as I swim that direction. If I put 4 of the 65 watt ColorLogic Universal Networked lights on the south wall in the 50 feet that covers the shallow and the deep, I wonder if two 320 nicheless lights that are 23 watts each would be enough to reach across the 25 width of the sunshelf. What do you think?
    Another question, I want to have the 4 large lights even on the wall and I read that the optimum level for a light is 12 inches below the waterline. Is that true and do you think that will throw enough light to the bottom of the pool where it is 9 feet deep?
    Dec 2015
    Chattanooga, TN
    38
    Quote Originally Posted by Karen14 View Post
    The Hayward person didn't tell you the whole story. The other difference is that the Univesal ColorLogic light - if it is Networked - is the latest technologically and will be able to be updated when the new OmniLogic module is finished where the 4.0 will not. Having talked to 6 or 7 Hayward tech guys in the last week, I have learned that if you are really depending on some technical aspect, you better call back and confirm it with at least one other tech guy. All tech guys at Hayward were not created equally.
    Feb 2016
    Albany/NY
    91
    Quote Originally Posted by BrownEyedSusan View Post
    Thank you, I just confirmed that as well. We are going to go with the 12v universal lights that are networked and one 320 12v accent light that is networked as well. I hope they will all sync together.
    Emersonsdad's Avatar
    Mar 2014
    Bakersfield, Ca
    152
    I have intellibrites and love them so far. On my sunshelf I did 2 globrites and it looks great. They sync up with the intellibrites. The light on the left is a intellibright spa light and on the deep end on the right is an intellibrite pool light.
    20K gal 32'x24' 4 bubble free form gunite pool w/ Midnight Blue Quartzscapes
    8' deep/3 1/2' shallow w/ 2 benches, sun shelf, 4' sheer descent, 4 deck jets
    All Pentair Equipment- Intelliflo VS pump, Clean and Clear Plus 420 filter, Easytouch 8 w/Screen Logic Controller, IC40 Intellichlor SWG, Intellichem w/acid container, Intellibrite 5G Color LED pool & spa light, 2 Globrites
    Feb 2016
    Houston
    323
    I spoke with one Hayward rep that said the new network lights will work with the prologic if it has the light module. I better call back to confirm that I don't need the omnilogic instead.
