Thread: Suggestions for 1 month absence from pool
    I'll be closing on my new house in about a month. The house has a pool that will be open when we close. I just got my TF-100 test kit and plan on using the BBB method to care for my new pool. I'm planning on taking it with me when we close and testing the water. The problem is we'll only be at the new house for 2 days after closing before returning 8 hours to our current home. It'll be 3-4 weeks before we move to the new house for good.
    There won't be anyone at the new house to care for the pool during the 3 week absence.
    What should I do to the pool (water chemistry, etc -wise) to reduce the chances I'll be returning to a swamp when we get up to the house?
    40'x20' IG vinyl, ~30k gal. pentair triton II sand filter. 3/4hp Hayward Super Pump. TF-100 test kit.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Suggestions for 1 month absence from pool
    It's really hard to tell you, as we'd just be guessing. In theory, if the water is properly balanced on the closing day, you could shock the pool and then put in a floater with some tabs. But if the water is not balanced, that may not do you any good.
    Will you have a way to post the test results on the day of closing, so we can advise you then and there? IF their numbers are way-off we may advise you to just wait and let it go, and do some draining/refilling etc. after you move in, or we may advise you to just shock it and let it go, and then deal with the green swamp after you take over.
    The other option is to see if you can find a local pool service that would grant you a one month service contract.
    Too many variables here, sorry, wish I could give you better advice.
    Feb 2008
    Denton, TX
    5,061
    Does the current owner use a pool service? If so, the pool service will often extend an offer to you to "provide a month of free service because you are so busy moving" sort of thing. If they do this, take the month and let them handle it. Then take over on your own once you move in. If that's not an option, then do what poolmom says and see if you can find a pool service that will handle it on a month-to-month basis. Better yet, talk to your realtor about it. Realtors have HUGE rolodexes full of contacts for things like this. I doubt that this is the first time your realtor has run into this very situation with a client.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by 257WbyMag
    When we moved to Fort Worth the previous pool service offered this several times to us. They even let us use an auto water fill device. I would look into it.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Apr 2009
    Orange Park, FL
    104
    Quote Originally Posted by frustratedpoolmom
    I'd suggest taking Mom's advice one step further by placing a mesh cover over the pool so that the skimmer doesn't fill with debris, that's assuming the pump and filter will be operating during your absence.
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
