Thread: positioning pump and filter for new pool
    Dec 2015
    Mt Airy/NC
    13
    Yesterday my contractor came to grade out for my AG pool. In the process he wanted to know where I wanted the pump located, and I pointed out the area, which is on the uphill side of pool, closest to my electrical source. Then he mentioned he would have to dig out a slot for the equipment because the pump needs to be near the base of the pool. Shortly after they left, I realized that having this dug out area for the pump would be where the ground water would fill and flood the electric motor, or at least shorten the life of that equipment. I don't see why the motor couldn't be three feet below the surface of the pool instead of four feet? Now when the do the actual installation I'll fill that slot in again and move the pump more downhill, unless you believe I'm not in error on my thinking. Thanks for any input on this.
    17k, 27'AG, Sand, 2spd Pentair, Hayward Aqua-trol salt system, TF100 tst kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: positioning pump and filter for new pool
    2 to 3 feet below the water surface level will work fine. Even 1 foot is OK.
