Results 1 to 10 of 10
Thread: Water was golden yellow...
    Sep 2013
    Charleston, SC
    537
    I have never seen this much pollen before. I back-washed last night (didn't think to take a video until it was finished), and the water was literally golden yellow for about three minutes. The hairnets in my skimmer basket haven't been caked with pollen like some report on here and it obviously let all the pollen through. I wonder if pantyhose or an actual skimmer sock would catch the pollen?
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jun 2014
    15,143
    Re: Water was golden yellow...
    Crazy year for weather. Hairnets may have slightly larger gaps/holes than other products. Just a matter of trying different things and seeing which one you like best. I actually like the 1 gallon paint strainers from the local home improvement store.
    Sep 2013
    Charleston, SC
    537
    Thanks. I might venture out to the big box store (anathema to me most of the time!) and pick some up.
    Aug 2014
    Northern IL
    4,615
    When I use the paint-strainer type, I use 2 in each skimmer. Not much gets through to the second one, but some does. I 90 degree the seams.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,324
    Quote Originally Posted by Texas Splash View Post
    Same here...they last MUCH longer than skimmer socks which literally fall apart after a few weeks use. though I think the skimmer socks catch slightly finer dust.
    Interesting Marian, I might try using two as well to catch any that slips by the first.
    Dolphin E10 Cleaning Robot.
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Quote Originally Posted by borjis View Post
    Odd that your skimmer socks fall apart so. We've got some that are going on their 3rd year. Skippy rinses them out with the hose and tucks it back into the basket. A few have lost their stretch and were tossed, but they were probably at least 2 years old?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have tried both and I think the hair nets strain finer than the paint strainers, and have the added advantage of being disposable ( at $6 per 100). If you have a huge amount of pollen and you use something that catches all of it, you will either have to clean/replace skimmer socks every hour, or you will starve your pump. There is a limit to how fine you want to strain the water at the skimmer.
    chiefwej
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,324
    They might have not lasted long due to my chlorine levels....at my last house/pool I used them on it was really high due to cya 90.
    Sep 2013
    Charleston, SC
    537
    Quote Originally Posted by chiefwej View Post
    The hair nets caught none of the pollen or very little of it. I don't want to filter to a fine level, but it was truly dazzling how much pollen came out in the back-wash. I will try the paint strainer and see if I see a difference this weekend.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Paint strainer gets less than the hair net, ladies knee highs are slightly finer than the hair net. If you want to get even finer filtration you might try the regular skimmer socks.
    chiefwej
