Results 1 to 17 of 17
Thread: Okay it Happened, I Spilled Bleach
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Okay, the subject line says it all, the splash put spots on my pants and maybe affected a flagstone. I ordered a Liquidator. I can buy a paver to put the Liquidator on beside my equipment pad. My point is, adding liquid chlorine directly to the pool is not without its own set of hazards. I knew this would happen. it did take 40 days. I will not make the same mistake again. All in all, I am a believer in TFP, but adding that liquid chlorine at night is a prob. to me.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Re: Okay it Happened, I Spilled Bleach
    In the world of desktop programming, from which i come, I would say adding liquid bleach directly is effective, but less than "user friendly"
    Jun 2014
    Roseville, CA
    343
    I kneel down on a foam gardening pad and pour carefully without splashing in the return water stream, same with acid.
    Treat you chemicals with respect.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Aug 2014
    Northern IL
    4,615
    Ha! My wardrobe is a polka-dot mess.
    I DO have dedicated "pool clothes" but I usually decide, "What the heck. It'll be fine...I got this... I won't splash this time...." More polka-dots. I just dislike changing clothes. No; I am lazy.
    Get a set of pool clothes and don't be lazy like me!
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Quote Originally Posted by MarianParoo View Post
    Apparently I am like you
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I polka dotted a few shirts before I started floating the bottle in the pool and tipping it so that the opening is less than an inch above the water and pouring it. Two advantages here, no splash whatsoever and you don't have to hold the weight of the bottle. Double winner chicken dinner!
    Aug 2014
    Northern IL
    4,615
    You are right, pooldv. That is the best solution!!!
    It's just after all these years, I kinda-wanna be done with the pool at night... and it's getting harder and harder to bend over the pool as I get older... Polka-dotted clothes are the pool owner's badge of honor!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    hmmmm, I know some people just can not bend over to pour bleach, I have heard a way to pull water out of the pool here and I think it will work great for this..
    cut a 4 or 5 foot 2 inch PVC pipe, put 1 end in the pool over/ in front of a return and pour into the PVC pipe...
    You could also get one of these and use instead But you would have to pour into it first.. The nice thing would be you could put marks on how much was needed per day and put 2 or 3 gallons in it at a time
    Amazon.com: VP 5 Gallon Square White Racing Utility Jug With Deluxe Filler Hose: Automotive
    Jun 2014
    15,189
    Apparently, many of us shop for clothing at the same TFP designer wear source. Dot, dot dot dot, etc.......
    Jun 2014
    Rogers, AR
    427
    Add me to the list of polka dotted clothes.
    I just commented to DH that Atwoods changed their bottle this year they also added the dreaded seal to the bottle. Now it splashes and those stupid seals never rip off the way they are supposed to.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Quote Originally Posted by Chrissykr View Post
    Yes, very astute. The dreaded seal is what ate my lunch. If it does not come off properly, be afraid. BE VERY AFRAID. Good to know its not just me.
    Aug 2014
    Northern IL
    4,615
    Yup. Be careful. A flying splash-drop from those dreaded seals can get you in the eyeball. Been there once and went for a quick, open-eyed swim with my polka-dotted clothes on.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Quote Originally Posted by MarkTX View Post
    Lol! I can relate.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Texas Splash View Post
    Essential Links:
    Feb 2016
    Gilbert, AZ
    10
    Yup, love my polka dot pants!
    It could be much worse... A few weeks ago I had a bottle of acid tip over and leak in the back of the car.
    ~11,200 gallon in-ground, built ??, pebble tec, hayward 1hp single speed pump on timer, hayward 3025 cartridge filter, TF-100 test kit
    DFW, TX
    24,502
    Bummer!
    Casey's Avatar
    SW PA
    10,450
    I have ruined many a t's doing the TFP.
