Thread: Please help! Pentair intelliTouch not working.
    Mar 2016
    Las Vegas/ Nevada
    1
    Hello all! I'm new to this site and hoping for some help. I have a intelliTouch LED indoor control panel (P/N 520138). I have my pool/spa light and the pool pump set on timers for on/off. My issue is that in the last few days, the pool pump will not turn off on the designated time. The pool lights turn on and off correctly and the the pool pump will turn on correctly but not off. Did I bump a setting somewhere? I did just adjust the time for DST and i don't know if that's when it started not working. Any info would be helpful! Thanks again!
    Feb 2016
    Spring/TX
    57
    Re: Please help! Pentair intelliTouch not working.
    How old is the system?
    40k Gallon Grecian true L Gunite Pool/Spa. Clean clear plus 520 cartridge. IntelliFlow VS-3050. Polaris booster pump w/ Polaris 360 cleaner. Silencer 1 1/2 hp Blower. Aqualink RS8 w/ Iaqualink 2.0 upgrade kit.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Is the time of day correct on the unit?
    Does the pump eventually turn off at some other time?
    Go into the program editor for that pump and look in the upper right corner of the display. It should display what might look like a fraction. First number being the program you are currently editing. the second number will be the total number of programs for that aux (filter pump). If it is any number other than 1, you may have an overlapping of programs that could be causing your symptom.
    Factory Warranty Station for:
