Results 1 to 8 of 8
Thread: Quiet Pump
    Jan 2016
    TX
    157
    Quiet Pump
    I'm finishing up a pool build and my water features have a 1.5HP pentair Whisperflo pump Model #011773. The pool/spa pump is a pentailr VS 3PH model# 011018. The water feature pump is way too loud and needs to be changed out. The 3HP Pool pump at full speed setting is probably half the dB of the "Whisperflo" pump.
    I'm going to see if the PB will swap it out with a quieter pump, if not any ideas of quiet single speed pumps? I don't mind buying another VS pump if that is the only route to get the sound level needed but would rather save the money with a lower HP single speed since the pumps only requirement is running (3) 24" water sheers.
    Is it possible to just purchase the motor/VFD assembly for the same VS pump I currently have and mount onto the 1.5HP pump housing(correct term?)
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    Feb 2016
    Spring/TX
    57
    Re: Quiet Pump
    You would need the motor, drive, and the impeller to get that working
    Last edited by RedBluePool; 03-24-2016 at 10:10 PM. Reason: I was totally wrong on diagnosing the problem
    40k Gallon Grecian true L Gunite Pool/Spa. Clean clear plus 520 cartridge. IntelliFlow VS-3050. Polaris booster pump w/ Polaris 360 cleaner. Silencer 1 1/2 hp Blower. Aqualink RS8 w/ Iaqualink 2.0 upgrade kit.
    azpoolpros's Avatar
    Mar 2016
    Chandler Arizona
    4
    Re: Quiet Pump
    Is is possible to swap the single speed for variable speed yes. wether or not it will help I dont know, sounds like the pump is staining to move the water around, could be a total dynamic head issue. ive had it where the pressure side just needed to be closed off a little and the system would quite down.
    Jan 2016
    TX
    157
    Re: Quiet Pump
    Quote Originally Posted by azpoolpros View Post
    I have regulating valves on each sheer, I'll play around with closing them off some tomorrow.
    Re: Quiet Pump
    The WhisperFlo is a high head pump, which means that it is designed to push water against a lot of resistance. Most water features have low resistance. In most cases, a WhisperFlo is a very bad choice for a water feature. Pumps all have a head curve. Within the curve is a designated best efficiency range.
    The pump should always be running in the best efficiency range. Outside of the range, they can be very noisy. In some cases, the noise is caused by cavitation. Almost definitely, the Whisperflo is way to far to the right on its head curve.
    A pump designed for low head would probably be a much better choice. It would be much quieter and it would use much less electricity. There are dedicated water feature and waterfall pumps. To get the correct pump, you have to know the specific requirements of the water feature.
    Can you describe the water feature? Make and model. Height above water?
    Do you want a solid sheet down to the pool surface?
    What size pipes are the suction and pressure pipes?
    How far is the pump from the pool?
    Support the site
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Quiet Pump
    We replaced our main pool pump last year with a Whisperflo 1.5 hp and you can barely hear it a few feet away. I wonder if some back pressure is causing the increase of noise.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Re: Quiet Pump
    It's not back pressure causing the noise. It's actually lack of back pressure causing the problem.
    If there's less head loss on the pressure side, there's an increase of head loss on the suction side. If the head loss gets to about 32 feet on the suction side, the water can boil and convert into steam and create voids in the water (cavities, hence the name cavitation). As the steam goes from low pressure on the suction side to high pressure on the pressure side, it collapses creating a loud noise. This usually happens as bubbles, which make a sound like rocks or gravel traveling through the system
    Adding resistance to the pressure side can quiet things down in cases of cavitation because it reduces the suction and can keep the water from cavitating. However, the best solution is to get a pump whose head curve crosses the system curve at the correct operating point and is within the designated best efficiency range.
    Do you want a single effect from the sheers or do you want the ability to control the flow?
    A medium head variable speed pump can be a good choice. You could also skip the extra pump and just add valves to send return water to the sheers. If you have automation, you can use valve actuators to run on a schedule.
    Support the site
    Jan 2016
    TX
    157
    Re: Quiet Pump
    Correct.. I choked the regulating valves down to the minimum flow to still keep a sheet of water out of each sheer and the pump is now extremely quiet!
    The sheers are a one trick pony, so with their current valve positions and dB levels I am good to go.
    Quote Originally Posted by JamesW View Post
