Thread: Where should I connect a zinc anode.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,912
    I have a SWG pool and thought it might be a good idea to help protect the equipment from corrosion with a sacrificial zinc anode. My thought was to connect to the bonding wires near my heater and bury a zinc bar as a sacrificial anode there. Any thoughts or suggestions?
    chiefwej
    JoyfulNoise's Avatar
    May 2015
    12,930
    Re: Where should I connect a zinc anode.
    Sac anodes work best when connected as closely as possible to the thing you want to protect. The funny thing though is that copper (i.e., heat exchanger) is fairly stable and unlikely to suffer galvanic corrosion. You can certainly hook it up to the bonding wire but the things that need the most protection are iron based materials like stainless steel hand rails or wrought iron fences.
    You need to bury it in moist soil. Being a fellow Tucsonan, you'll have to tell me where you find such a rare and mythical spot
    Matt
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,912
    Maybe if there is a leak somewhere in my equipment area and I bury the anode there, but otherwise you are correct, moist soil is a very rare commodity around here.
    chiefwej
    May 2015
    12,930
    I was thinking of you had a nearby irrigation drip line that would be perfect.
    Matt
    Aug 2015
    PA
    74
    My PB is installing one of these in my build. Model 104-D
    http://www.pooltool.com/anodes.html
    New salt diving pool started in February 2016. Approximately 42x20 kidney shape. 100 sq/ft tanning shelf. White Plaster. 2 Pentair 5g Color LEDs and 1 Color Globrite LED. All Pentair equipment. DE filter. Kreepy Krauly 820 robotic cleaner. EZ touch wireless system. 860 sq/ft Techo-Bloc paver patio with matching fire-pit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,350
    Quote Originally Posted by rccarps2 View Post
    Tell them not to, those put zinc (metals) in your pool water and that is not something you want to deal with....
    this is what I used and bonded everything together... This zink anode is 30 times bigger than the one you listed and for my pool should not ever need replacing in my lifetime and its about 70 dollars cheaper.. I also buried mine within a foot of my equipment pad where it will get watered by emptying the pump filter, cart filter and purging air from my filter.
    I know this "may or may not" if it does not work I am out 17 dollars but if it does work YAY
    6 lb Crab/Lobster Pot Zinc Anodes: Metal Anodes: Amazon.com: Industrial Scientific
    Amazon.com: Burndy Waterbug Pool Water Bonding Kit Ul: Kitchen Dining
