Results 1 to 10 of 10
Thread: TF-100 Test Kit Chemicals Still Good?
    Jul 2015
    Pittsford, NY
    32
    Hey all,
    I bought a TF-100 full kit in the middle of pool season last year (mid-July). I have plenty of each chemical left over, and was wondering if there is any reason to believe that any of the chemicals have lost their effectiveness over the past 8 months? Are any of the chemicals more likely to degrade than others? Pool season is still a couple months away, but I am trying to determine if I should buy a fresh refill kit. Thanks!
    Jun 2014
    15,159
    Re: TF-100 Test Kit Chemicals Still Good?
    If you kept them in a cool, dry place (i.e. indoors), they should be fine.
    Jul 2015
    Pittsford, NY
    32
    Yes, they were stored in a cabinet in my basement. Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    If any of the bottles are discolored, the reagent inside is bad and you need to replace it. Otherwise, they should still be good.
    May 2014
    Clarksburg, WV
    331
    I will say this. My first year with a TF-100 everything was fine. The next year my FC test seemed off. I dont really have a good reason to believe this, but it seemed low. So i bought a refil of the powder and liquid. Tested with the old powder and liquid....Got a FC of 4. Tested with the new stuff.....Got an FC of 6. I repeated this test 4 or 5 times just to make sure. each time i got 4 with old and 6 with new.
    The test chemicals didnt go bad, but they degraded????? I have some left over this year. I'm going to try the same test again this year....I have some powder and liquid left over again. Maybe it was just bad test reagents to begin with.....
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    38,302
    All the TF-100 reagents are about as fresh as you can get when you buy since they are made from bulk containers directly from Taylor. Certainly fresher than many kits that sits is stores for who know how long.
    I have never seen any of the reagents degrade, although maybe I use up the FAS-DPD stuff more quickly. I was still using some 3 year reagents for some of the tests and the results were as expected and comparable to my newer reagents.
    I store my kit in a closet in the house.
    jbriggs1219's Avatar
    Apr 2015
    Brunswick/Ohio
    77
    Unfortunately I had same issue testing chlorine as Kris...love my tf100 but was definitely a significant difference...and I always store my kit in basement...cool and dry all the time...no worries though..happy to order a refill each year...this site and proper test kit saves me mega $$$
    13,500 gallon AG
    Cartridge Filter
    Raypak Natural Gas Heater
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    My chlorine test powder gets a bit clumpy over time, which makes it a little harder to dissolve. I might just order a refill kit this year just to be sure everything is good. $38 isn't a lot of money when you consider how much a lot of people drop at the pool store.
    38,302
    You can smash the clumps up if they get to bad.
    Jul 2012
    Chicago, IL
    356
    My calcium and TA test regents are still originals which I bought in maybe August of 2012. They seemed to work fine last year... not sure if I will push it at almost 4 years old, but they have always lived in a cabinet and I rarely need to test those.
    The others I go through more quickly, but as other note, if stored in a reasonably temperate and dark place I would expect them to be good for at least 12-18 months.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
