General Questions
cjbyrd
Mar 24, 2016
37
Destrehan, Louisiana
Jandy Aquapure 1400
Hello I just joined TFP today, I moved into a house 2 years ago with a 16,000 gallon in ground gunite plaster pool. I've never owned a pool before and Last season I was bringing my water to Leslie's Pool to get tested and was spending a fortune on chemicals and my water was never crystal clear. This year I bought a Taylor test kit and will be testing the water myself and will be using the BBB method I've been reading about. I drained my pool and pressure washed it, and as of now my chemical readings are PH 7.4, Alkalinity 110, Calcium 260, Chlorine 4, Free Chlorine 0, CYA 40. I also bought a Phosphate tester and Phosphate level is 0. My plan is to use cal-shock when I need to shock my pool and 8.4% bleach to add chlorine. My question is when testing the water do I add drops till the color just changes or keep going till it changes and gets darker. Also, which chemicals change the most throughout a typical week or month such as should I test chlorine and PH more often than everything else etc? After adding chemicals how long should I wait before retesting and after shocking pool how long before I should retest? Thanks in advance of all of you help.
Welcome! :wave:
You're in for a disappointment. We don't shock routinely. Why? Because we don't get algae! Maintain adequate chlorine levels for your CYA and you may never get algae either. Some of us have gone more than five years without ever seeing green water, 365 days a year. Your CH is on the low end, so you could use Cal-hypo for your daily chlorination for a little while, but if you haven't already bought it, don't. Just stick with bleach.
Your FC level needs daily attention. Judging by the high TA, I'll guess the pH will need adjustment a couple times a week for a while, and then maybe weekly. The only way to be sure is by testing. CYA will only go down by splashout, rain overflow, or backwashing. CH will slowly climb through evaporation and refill, unless you choose to use Cal-hypo to chlorinate. TA isn't really all that critical except to calculate acid dosages. By the time it needs attention (if it ever does) you'll be experienced and knowledgeable enough to deal with it yourself.
For testing, you count drops until the color changes and keep going until the last drop doesn't change things and deduct that. In your case, your TA test starts at green. Probably around 9 drops it turns greyish. At 10 it's pinkish. At 11 it's even brighter pink. 12 doesn't change anything. Deduct that useless drop. 11 drops. TA is therefore 110.
I'm going to recommend you spend some time in Pool School. Start with the ABCs and How to Chlorinate and Recommended Chemicals and How to use poolmath.
One other question about the chlorine level for CYA, with my CYA at 40 what chlorine level should I be at? and thanks again everyone for your help.
Pool School - Chlorine / CYA Chart
Also, if you enter your pool's particulars down in the last row of poolmath, as you fill in the current readings, it will set the recommended target levels for you.
Couple of other questions. I forgot to mention in my original post over the winter I was talked into buying and installing one of those Zodiac mineral cartridges. Will that cause any kind of issues with my pool or am I fine just leaving it? Also, to get an accurate reading how long should I wait after adding chemicals to test the water again? Thanks again.
Pull the zodiac out and move on. The minerals can cause problems with staining and turning hair green over time. Chlorine is the best way to go.
Testing after adding----make sure the pump is running and wait about 15 mins before testing. A good brushing will be a good idea to help mix it all in.
Kim
An elevated FC level (over FC 10) will give misleading (high) pH readings. Extremely high FC can also make some of the other tests react differently with their respective colors. But generally, the only one that you hear the most is once someone is doing a SLAM, with an FC over 10, they are reminded to not test pH anymore until the SLAM is complete.
Any advice on maintaining CYA levels with an in line chlorine tablet feeder.
You can’t maintain CYA with a puck feeder as the trichlor continuously adds CYA. For every 10ppm FC added by trichlor, you will add 6ppm CYA. So if you choose to use the inline chlorinator then you will have to measure CYA frequently, probably twice per month at a minimum, and adjust your target FC value as the CYA increases.
The only way to hold CYA constant is to use non-stabilized forms of chlorine (liquid chlorine or bleach) OR to use PoolMath to figure out how much water to drain and replace to reduce a given amount of CYA. So, for example, you might say every time the CYA goes up by 20ppm, you’ll drain and replace water to compensate.
Not using stabilized chlorine tablets in the first place is easier than water replacement in my opinion. But to each his own...
Thank you for the info, I've been using a Polaris to clean the bottom of my pool and rarely vacuming my pool. I may start vacuming to waste every 2 weeks to keep the CYA from buildng up. I probably should be vacuming more often than I have been anyway.
Ideal CYA Levels
I have a 16000 gallon outdoor chlorine pool built in the 80's. What is the ideal target CYA level to maintain? Also anyone know why there isn't a company making chlorine pucks that don't add CYA? Seems like they would own the chlorine puck industry if they made something like that.
This varies from pool to pool because of many factors, most notably amount of use and amount of direct sun. The weather is picking up, so I would expect us in the the south need at least a CYA of 40 to start with and evaluate the consumption of FC. If the FC drops too fast in 24 hrs in an algae-free pool, then it might be time to increase the CYA to 50. My pool for example receives full sun from dawn to dusk. I run a CYA of at least 60 in the summer to maintain an FC loss of around 3 ppm in 24 hrs. Some more, some less depending on the amount of swimming and cloud cover. So you'll have to experiment a bit as well for your pool.
