Results 1 to 8 of 8
Thread: Which options with the TF-100 should I purchase?
    May 2015
    Fullerton, CA
    634
    Should have water in a couple weeks need to order the kit, I see there are several optional tests I can add. Do I need them? If so, which ones.
    thanks!
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: Which options with the TF-100 should I purchase?
    The automatic stirrer - LOVE IT!!!!!!!!
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    38,235
    On a new fill, you likely should not need the XL option. I would highly recommend the SpeedStir. You also may want a salt test (even though you should not add salt for 30 days) ... I prefer the Taylor drop test.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Speed stir is a must.
    With my new pool, I have found that I go through my phenol red (pH measurement) and CYA-measurment reagents faster than everything else. This year, I ordered an extra supply of these 2 things.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    SpeedStir makes testing faster, more reliable and FUN!
    Drop-based salt test for once you put salt in the pool.
    That's all you should need.
    Isolated Spa - 345 Gallons
    May 2012
    Florence, AL
    20
    Speedstir without a doubt.
    33k Gallon IG Freeform Gunite built in 1989 - Renovated Spring 2012 with Diamondbrite Plaster and elevated spa converted to waterfall
    Jandy Aqualink PDA Automation & Control System - Jandy PlusHP 1.5hp Full rated Pump - Hayward 36in Sand Filter - Jandy Aquapure 1400 SWCG
    TF100 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like the others said, Speedstir is by far the number one must have option, distantly followed by the sample sizer, it took me 5 years of using the TF-100 before adding the sample sizer and some extra Taylor branded test tubes that you must use with it, but now I am glad I did.
    May 2012
    Florence, AL
    20
    Quote Originally Posted by Isaac-1 View Post
    I've been using a 60mL syringe (no needle of course) to draw water from the pool for my samples. Then I just squirt the required amount into the sample tubes; no mess. It holds just enough to do my three most often done tests, pH, TA, and FAS-DPD Chlorine. They hold up pretty well. I've been using the same one since 2012.
    TF100 Test Kit
