Thread: pool accessories
    pool accessories
    We are in Mass and getting ready to open our pool. It was installed last year so this is our first opening! I am interested in getting some steps, the ladder we had is a piece of junk! I was thinking about the majestic 8000 found here http://www.innovaplas.com/en/s.php?s=2819544474 any thought on these?
    also, I am considering buying a solar cover, to help warm up the water. my pool is in direct sun ALL day long. would the 8mm be okay for us?
    Thanks!
    Sharkline 18x33 54"AG, Hayward 1.5hp Perflex D.E., TF-100 test kit
    Finally....a pool of our own!
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Re: pool accessories
    Personally I like anything AnovaPlas makes as far as steps go...I hate the fact that I had to take mine back last year because they came with a ladder system that was not self latching...The ladder system that the pool stor gave me sucked big time.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I have 8 mil and it basically works as well as my old 12' mil spaceage cover... no difference IMHO.
    Thanks! I think I will get both! I don't think we will regret it!
    Holly
    Jun 2008
    Port Neches, Tx.
    144
    Those steps look good. We've got some that are similar to those.
    I like the removable sand weight, ours the weights (3) are attached to the inside of the steps making it quite heavy and hard to get over the side of the pool when I take them out. I also like the feet on those, they look like it should get good circulation.
    I've just drilled quite a few holes in ours to try and improve circulation.
    I would recomend keeping a close eye on the underside of the steps to make sure leaves and what not isn't accumilating there.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    Jul 2008
    Solon, Iowa
    170
    I have InnovaPlas wedding cake steps (the older version) and like them a lot. The older version is quite a handful to get in the water and then get weight in the steps to sink it (via the cutout in the back), but worth it in the end. Note that the railing is made to connect to the deck with screws. Also, leave a few inches between the back of the steps and the inside pool wall so you don't interfere with the circulation pattern and get stagnant water. I didn't have any algae problems (under, around, or inside) but nevertheless I'm going to drill some more holes in the sides to improve flow through the step cavities and avoid stagnant water. I wish that I had those suction feet in the new ones for that same reason. They make a light that fits into one of the steps which is a clean way of getting an underwater light in an AGP.
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
