Results 1 to 15 of 15
Thread: Question about in wall skimmer vs over the wall skimmer
    Jun 2013
    west fargo
    72
    I have read over and over how to install a in wall skimmer in my intex just wondering.
    If it a lot better than the over the wall ones? I use both the over the wall on a separate little filter.
    20'x54" intex ultra Sand filter. with SWG Still work in progress will have Resin 24" fence around the top. Hooked to a 10x6 Deck that is attached to another 10'x6' Kids Club house. Slide from main deck into pool. Intex softwall lights. Kenwood Marine radio sealed in a deck box all Bluetooth controlled with Pyle 5" outdoor speakers.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Question about in wall skimmer vs over the wall skimmer
    Yes, you will not regret it
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2013
    west fargo
    72
    Do I have top keep the water down lower in the pool? I know it will have to be below the seam that goes around the top of the pool but can I just have the water level. Right below the top edge of the skimmer? If that makes since. I don't want to loose much depth in the pool.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    wall skimmers work best half full, but I sometimes have my level close to the top so it is deeper, no problems unless kids splash alot. The waves can push water through the skimmer top opening.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    http://https://goo.gl/photos/p2SmsNJvVcfaEJjo6
    Hope you can see the picture, let me know please.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by Piolin View Post
    cant see the pictures, use a site like imgur Imgur: The most awesome images on the Internet
    here is how I did it... post number 93, i followed the many posts on here on how to accomplish this..
    New above ground oval 18x33 install - Page 2
    Jun 2013
    west fargo
    72
    Awesome thanks. I am placing my order this weekend then. Looks like it is a great upgrade. Just scared to cut the liner LOL.
    Jul 2013
    Fletcher, OK
    3,353
    The soldering iron for the corners worked GREAT, then just a new razor blade nice and slow along the line... Mine has been there a year now, made it through winter with no issues and works perfect now that it is opened again...
    1 Caution, most everyone does this with almost no water in the pool... the vinyl does have major pressure on it when the water is filled (that's why so many screws in the skimmer) Just something to watch
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,522
    I only drained to just below where I needed to make the cut. Don't worry, it won't tear.
    My thought was that it was better to have the liner fully stretched out when making the cut, versus installing the skimmer and having the hole stretch out when it was filled.
    This is a great upgrade, you won't regret it. You pool will stay much cleaner.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jul 2013
    Fletcher, OK
    3,353
    I agree 100% Jeff worth every bit of it
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    100% worth the effort. I installed the skimmer without removing any of the water. I had a little water escape when I made the screw holes, and I had the bottom of the skimmer capped off before I cut out the square hole. I usually have my water level about 3/4 the way up the skimmer door, so I lost an inch or so in depth.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jun 2013
    west fargo
    72
    So which wall skimmer does everyone recommend? I been looking at a few on amazon just not sure which is the easiest to hook into the piping I already have.
    Great info everyone thanks for all the help by the way.
    Jul 2013
    Fletcher, OK
    3,353
    I used 2 inch PVC in mine to connect everything, are you planning to do this also?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,522
    Amazon.com : Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer and Accessory Kit : Swimming Pool Skimmers : Patio, Lawn Garden
    It comes with an improved return eyeball and an adapter so that you can use a real pool vac too.
    The only drawback is that it doesn't thread directly to the Intex hoses, so as Casey mentions, you'll have to fashion something to adapt them. I also used a few dollars worth of PVC to make mine. It's easy.
    Pentair IC40 SWG
    Jul 2013
    Fletcher, OK
    3,353
