Thread: Sodium Carbonate vs. Sodium Tetraborate?
    Mar 2016
    Medford, Oregon
    180
    Question Sodium Carbonate vs. Sodium Tetraborate?
    I was planning to buy a box of 20 Mule Team Borax to raise my pH level. However, I noticed that the box listed the ingredient as sodium tetraborate & not sodium carbonate as mention in this forum. Are they the same?
    Thank you kindly.
    Kit
    Kit
    14' X 11' rectangular in-ground spa; 2,360 gals; plaster/gunite; SWCG (Pentair IntelliChlor); Pentair Intelliflo varaible-speed pump; EasyTouch4 control system; cartridge filters; auto cover
    38,275
    Re: Sodium Carbonate vs. Sodium Tetraborate?
    sodium carbonate is soda ash, not borax. They are 2 different chemicals.
    Recommended Pool Chemicals
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Either will work. Soda ash will raise TA more than borax.
    When you use poolmath to calculate the dose for pH adjustment, it will give you the choice of which one. If you'll remember that amount and scroll down to Effects of Adding Chemicals and input the amount and select the chemical from the dropdown, it will tell you roughly how much the pH will change and pretty accurately how much the TA will change.
    Mar 2016
    Medford, Oregon
    180
    Oops! My error. Sorry. Thank you for the clarification.
    Kit
    Thank you, Richard. I have to admit that I never scrolled down to the Effects of Adding Chemicals section of PoolMath.
    Kit
    Kit
