Thread: Aquapure De error code
    Oct 2012
    GA
    4
    I just replaced the sensor on my Aquapure 1400 system. When it is running the screen shows that the power is on and there is a De code flashing. Does anyone have any idea what is causing this?
    Pool -27K Gal in ground (PebbleTech)
    Pentair Tagelus 60D sand filter
    Jandy Stealth SHPF2.0 pump
    AquaPure 1400 Salt System
    Jandy Aqualink PDA-PS8
    Jun 2011
    Long Beach, CA
    2,790
    Re: Aquapure De error code
    I'm not familiar with a De error code on Jandy Aquapure SWG's. It might have something to do with the automation side and even then I could not find that error code. Hopefully someone else can offer something else.
    Oct 2012
    GA
    4
    I received a response from Jandy and they said it means that it has loaded the default settings. I had never seen this before. My problem is now that it will not go away and it is supposed to. I think I am going to have to replace the board now.
