Results 1 to 13 of 13
Thread: Is it really this easy? (And finally, more pictures!)
    Feb 2016
    Near Toronto, Ontario
    48
    So, it's been three weeks that we've had the house, and life with an indoor pool is fantastic. We vacuumed for the first time last night, as there were some specks on the bottom of the pool from a backwashing fiasco (more on that in a minute).
    Numbers are looking great - FC started out near 10 (guessing the former owner dosed the pool just before we took over, in case we didn't get on it right away), and now we're running:
    FC - 3 to 4 (easily maintained, only changes when somebody swims)
    CC - 0 (some days not even a hint of pink)
    CYA - 0
    pH - 7.6 (rock solid - almost too solid, I'd like to bring the TA down with acid over time, rather than all at once)
    TA ~ 220 (high, yes)
    CH ~ 200
    Temperature - 79 to 81 degrees
    CSI ~ 0.4
    On the CYA front, the previous owner left us a bucket of dichlor - would it make sense to slowly add CYA by using the dichlor instead of bleach, until I hit about 20? It's not even worth testing right now, it's so low.
    We keep the pool covered when not swimming, and it really helps keep the humidity in the room down. No issues with fogging windows except for a particularly boisterous swim occasion so far. Air temperature around 82 when swimming.
    As for the backwash incident, the backwash line and the floor drains run out to the back of our property, and I think the end of the line is covered by a fallen tree. An attempt at backwashing resulted in the floor drains turning into fountains... they do drain, but not quickly enough - not ideal. I have acquired some tracer dye, and I will use it to find the (assumed to be) buried pipe outlet.
    And finally - pictures of the pool in its nighttime glory - uncovered and illuminated. I tried to take some underwater pictures, but they didn't work well with the lighting.
    Suggestions welcome!
    Approx. 22,000 gallon 15 x 30 tile lined indoor pool, Taylor K-2006, heat exchanger from main boiler, 3/4 hp Hayward Super Pump, SandMaster sand filter.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Is it really this easy? (And finally, more pictures!)
    Looking good!
    I would be suspicious of the CYA being 0. If the owner left you dichlor to use, they probably used it at some point. It's hard to know since the detection limit of the CYA test is 30 ppm. You really only know that you're <30 ppm. If you do add some dichlor to increase FC and CYA... keep track of exactly how much you add and test your CYA weekly and before adding any more.
    As long as your pH is stable, I wouldn't be very concerned with the "high" TA. TA is one of those numbers that's very subjective to each pool. The rule is: stable pH = leave the TA alone. Your CSI is OK, slightly high, but still OK. If anything, occasionally bump your pH down to 7.4 or 7.5 and over time your TA will come down, bringing your CSI down a bit as well.
    Great looking pool. Wish I had an indoor pool this time of year...
    Isolated Spa - 345 Gallons
    Jun 2014
    15,233
    There is one thing VERY wrong with this picture ..... NO ONE IS SWIMMING! Wow, that looks inviting. Crystal!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Are you SURE there is water in there?? SO clear and still!
    Good luck finding where the backwash water goes! I can only imagine your face when that happened!
    Kim
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Since it's indoor you don't really need any CYA unless the sun is hitting the water.
    Maybe he used the pucks because a lot of folks just do.
    Dolphin E10 Cleaning Robot.
    Sep 2013
    Charleston, SC
    540
    Please reference the CYA/FC chart Pool School - Chlorine / CYA Chart and look at the bottom for indoor pool recommendations of maintaining CYA between 20-30.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jan 2014
    Buckeye AZ
    807
    with a cya of 0 your FC is way too high. You only need 0.1 ppm to properly sanitize. Now, granted, that level of FC will disappear quickly when someone goes swimming. But if you keep the FC at 2, 3, or 4, so that it doesn't drop to 0, you are exposing people, swim suits, and equipment to a very high CL level. That is why it is recommended to keep CYA at least 20 ppm (or 30, so your testing is more definitive). This way you can keep most of your chlorine bound to CYA, and inactive, while still having enough unbound chlorine to kill organics. As you use up chlorine sanitizing, some other chlorine bound to the CYA is released. It's like a reserve that constantly is rebalancing, where you keep the pool sanitized, but not overchlorinated.
    "Most heterotrophic bacteria have very low CT values of 0.08 or lower such that one only needs the equivalent of 0.1 ppm FC with no CYA to kill 99% of them in one minute or less. So even lower levels of chlorine will kill bacteria faster than they can reproduce, but it takes a higher level of chlorine to inhibit algae growth. It's still relatively low, however, at around 0.06 ppm FC with no CYA to prevent algae growth"
    from here
    To CYA or Not to CYA...
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Feb 2016
    48
    Yep - planning to bring the CYA to the 20 to 30 range. The previous owner was using the bucket of dichlor he left behind - but it was a new fill, and the pool water was only at 65 degrees, so it was only using about one small scoop a week.
    We have tried to swim pretty much every day - there have been days where we just got home too late (between moving, working, and life) but rest assured, we get in there every chance we can. Those pictures were taken just before re-covering the pool for the evening. The water calms so quickly... after uncovering it, or after a swim, we're greeted with that crystal clear water - and we're going to do our best to keep it that way!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sure you can use the Dichlor to get your CYA in range, just be aware that dichlor will also lower your pH a little as it is acidic, but not as acidic as trichlor. Also it is probably best to set aside about 5 pounds of dichlor and use that, when it is done you will have added about 15 ppm of CYA to your pool, then retest, as it is far better to sneak up on the right level than to over shoot.
    Ike
    p.s. you might also want to try to get a 20 ppm range CYA testing tube from TF test kits, I know they can't ship Taylor test chemicals to Canada, but may be able to ship hardware, plus I don't know if the 20 ppm CYA tube is even a Taylor product. If they can't let me know and I will send you one next time I order refills for my test kit.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    curious, if it's indoor, why cover it?
    Feb 2016
    48
    Quote Originally Posted by borjis View Post
    It keeps evaporation down, which helps prevent humidity issues - mould, condensation, and so on. When we have it off, we keep the air temperature at about 2 degrees above the water temperature - but with the cover on we can actually let the room temperature fall to 72 without moisture problems.
    Aug 2014
    Northern IL
    4,615
    I am a dichlor user and plan to stay that way. Just be careful to watch the effects as it will affect several parameters simultaneously.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes, it really is amazing the effect a cover has on humidity around an indoor pool, although I tend to only cover mine in the spring and fall months, for the peak of summer I just run the high volume exhaust fans as they are less hassle than covering and uncovering in prime swim season.
    Ike
