Thread: Converted last year to salt pool
    Mar 2016
    West Chester, PA
    7
    Wish I had known about this site years ago. Converted Bromine pool to Salt Generator last year and so far very happy. Only issue I am having is low free chlorine reading. Running pump approximately 10 hours per day. From what I have read so far will increase running time.
    Windowman
    West Chester, PA
    25year old 36,000 Gunite with new quartz finish (2014), 1 1/2hp Sta Rite pump, 60sf Pentair DE filter,
    1hp Polaris 380 cleaner, SJ45 Circupool Salt Water Generator
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Converted last year to salt pool
    Welcome! How does the pool look? How are your readings? Increasing pump/SWG run time will increase FC production, but might be worthwhile to see if anything else is going on.
    Please add your pool details to your signature in your "profile" tab.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    If the SWG can't keep up now and it used to be able to, something is going on. You might have the beginnings of an algae bloom and you're barely keeping it at bay, or you just have low CYA and sunlight is stealing it. Again, how does the water look? Crystal clear, dull, cloudy, tinted green, chunky green, black? And what are your chemical readings, and how did you get them? Have you tried an overnight loss test?
