Thread: "LOW SALT" & "CHECK CELL" problem.......... solved.
    Oct 2015
    Loxley, Alabama
    6
    Not long ago I bought a house with a pool equipped with an Aqua Rite SWG system. This is completely uncharted territory to me, never having owned a SWG pool and my only previous pool experience was 45 years ago when I lived in Iran for a couple of years.
    The previous owner of the new-to-me-pool had the balance all screwed up because unknown to him the SWG was not functioning and he was "shocking" the pool nearly every day, thinking that the system needed a "little help". He also was running the pump 24/7 and told me that continuous running is necessary to keep the pool operating properly.
    After some research and some fiddling around, I replaced the surge capacitor on the control board and got the SWG working. I also started correcting the chemical balance, solving the black algae problem, reducing excessive CYA, etc. I finally got all that squared away.
    I also reduced the run time to a few hours per day and that's when my problems started. Each time I checked the Aqua Rite panel, it showed a "low salt" and "check cell" warning. Resetting the system, by turning it off and on, solved the problem and it would function properly until the next time the pump cycled off.
    The Aqua Rite trouble hot line clerk told me this is a symptom of a failed cell. I had my doubts since it produced plenty of chlorine once I reset the system each day and the voltage and amperage readings were completely normal. I gave the Aqua Rite tech all the displayed values, but the fact that they were all normal didn't seem to mean anything to him. He did not even try to explain how a seeming normal cell could produce plenty of chlorine and yet still need replacing. Nevertheless, I replaced the cell anyway because I foolishly believed the Aqua Rite phone talker, and I didn't know the history or age of the existing cell. It is hard to trouble shoot with zero previous experience coupled with bad advice from the factory. I asked for help on several pool forums, but got no help on the Internet either. The problem remained, so I replaced the control board. It was then that I noticed that the SWG continued to run when the pump timer switch shut off. This is, of course, completely wrong.
    Apparently, what was happening was when the pump shot off, the cell kept working until it depleted the salt in the water trapped in the cell (it is mounted horizontally, "belly" down). Then the board detected low salt, turned on the warning, and shut down the cell. When the pump was running, I could reset the system and it worked OK. Thinking back, I realize that I had been either checking the system when the pump timer was already running or I was turning on the pump manually as the first step when I arrived at the control panel. It never occurred to me to check the cell function with the pump off.............I guess I just assumed it was wired correctly since it was at least several years old. Stupid me.
    Connecting the SWG to the pump timer solved the problem. Unfortunately, I spent quite a bit of money on components that did not need replacing. The Aqua Rite people were of no help at all and actually led me down the wrong path, which cost me around five hundred bucks when it was all over.
    It would seem to me that anyone with experience with a SWG system could instantly trouble shoot my problem given the symptoms.
    So if your system is giving a "low salt" and "check cell" warning each time the pump shots off, yet functions normally when you reset it, it might be improperly wired like mine. Bottom line: The SWG should only have power when the pump is running.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: "LOW SALT" & "CHECK CELL" problem.......... solved.
    This is a perfect example of hindsight being 20/20. Not to defend Hayward support or say anything against you, this is a good reminder to step back and try to take in the whole picture while troubleshooting or even operating pool/pool equipment. Thank you for sharing your resolution and sharing your experience.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Nice post! Thanks for sharing that.
    Apr 2011
    Lynchburg VA
    393
    Great write up for those with SWGs. Did you ever look at the flow switch to determine if that was the reason the SWG was not shutting off? It sounds like the flow switch might be stuck as well!
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Wow...such a shame you have had such a run-around and a costly one at that.
    During your early investigations in to the problems did you ever test the salt level to be able to confirm that it wasn't a factor?
    Oct 2015
    Loxley, Alabama
    6
    Quote Originally Posted by YippeeSkippy View Post
    Yep....... many times, both using my own salt testing kit and taking a sample to the local pool store.
