Results 1 to 10 of 10
Thread: Starite/Pentair VS pump priming not right-just an annoyance I can't cure
    May 2014
    Inverness Fl
    53
    I have had 2 discussions with pentair about this to no avail, so I have to live with it, but it just bugs me when something does not run like it says it should.
    This is a Starite/Pentair VS programmable Intellipro pump.
    Here are 2 quotes from the manual
    "The priming feature ramps the pump to 1800 RPM and pauses for three (3) seconds. If there is sufficient water flow in the pump basket, the pump will go out of priming mode and run its commanded speed."
    "Priming sensitivity can be set from 1 - 100%. 1% means the pump is the most sensitive to sensing if pump has attained prime. Increasing % will decrease amount of flow needed for pump to sense prime. Increase the % if the pump clearly has water in the basket but is having trouble coming out of priming mode. Setting this number too high can cause the pump to think it has
    attained a prime when it has not."
    Am I reading these wrong or does the pump not work right, because neither of these functions seem to do anything. If I have my pump and valves set to sent water to the returns at 1500 rpm, the pump basket is full of water, no bubbles anywhere, even after the pump is turned on, which says the system is air tight, and drawing nothing but water, it is primed, it will pause for the 3 seconds, then run at the max (3450) rpm for the default of 20 secs. to prime, before dropping back to the selected 1500 rpm run.
    It shouldn't do this. It is primed when it pauses for the 3 seconds,you can tell and see it. And setting the sensitivity does nothing, it still tries to run it's guts out at max rpm, for the default 20 seconds, before running the selected rpm range I have selected. This is just annoying, or I'm reading this material wrong, that says it will do something it won't.
    Am I?
    mid 2014 12 X 30 12k gallons IG Plaster\Fl Gem Finish. StaRite\Pentair DE filter. StaRite\Pentair IntelliPro VS Pump. Pentair UltraTemp Heat Pump Unit. Intellichlor IC40 salt system (not up and running yet)
    Very hard well water-no iron. TF-100 Test Kit (the best)
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Starite/Pentair VS pump priming not right-just an annoyance I can't cure
    What do you have the priming sensitivity set for and have you tried raising it?
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Not sure what the issue may be but on my Intelliflo you can lower the priming RPM. Maybe lowering that will at least make it quieter and less annoying.
    May 2014
    Inverness Fl
    53
    Quote Originally Posted by mas985 View Post
    I have it set right now at 1. I have tried 20-25-50-75 on the sensitivity, with no difference in the ramp up of the pump. I don't understand when it is already primed, why it won't go to the designated (1500rpm) speed without trying to prime itself all over again, after the 3 second pause. There is 100% total volume of water moving thru the pump, it is primed.
    mas985's Avatar
    Pleasanton, CA
    11,742
    I would try 100.
    What is your filter pressure at full speed?
    Mark
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have a Pentair Intelliflo 011018 and regardless of what the manual says, every time is starts it goes directly to the max speed for at least 20 seconds before switching to the preset run speed. I have never seen it go through the 1800 rpm sequence as described in the manual, even when it was fully primed and was just stopped for a few seconds.
    chiefwej
    Dec 2014
    Houston, Texas
    134
    How about disabling the prime feature? I do this all the time as its function isn't geared toward our installs involving in-floor cleaner systems.
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    I think I have the same VS pump as the OP. It behaves exactly the same way. I messed with the settings a little to no effect. I decided not to bother about it, every day when the pump comes on, it spends a few seconds at 1800, then ramps up to the max RPM for priming (for no reason since the system is already primed), then eventually drops down to the RPM I set it to (1200). Oh well. Doesn't seem to hurt anything as far as I can tell.
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
    May 2014
    Inverness Fl
    53
    I would try 100.
    I tried raising the sensitivity today to 100, with no difference
    My filter pressure at 3450 is about 22 psi, just put in new material in DE filter about 3 weeks ago.
    I did this today.l
    Thanks to everybody for there opinion. As a couple of you have said, I believe that these 2 settings don't do anything. I have told Pentair this on the phone twice, and that this should be removed from the manual. Today, i spent an equal amount of time as before, trying different settings on the pump program, with different settings also with my pool valves, to try different water flow pressure, as in the water going thru the heater, the infloor cleaners, the returns. Made no difference at all. I turned the primer off, the pump now goes to set speed. If it needs priming, I'll prime it.
    Sep 2013
    Charleston, SC
    540
    I had the same issue as discussed in this thread Intelliflo VS Pump Priming every time power is turned off and in particular posts 10 and 11. The sensitivity setting seems to have absolutely no impact!
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
