Thread: plastic or brass
    Mar 2009
    eastern washington state
    plastic or brass
    I have a question about the plumbing on my pool? its was just put in last year and they used plastic ball valves with the plastic handles. Was wondering if i can replace them with brass or metal ball valves? I thought i saw somewhere on here not to use metal. the handles have broken off and they are hard to shut.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Re: plastic or brass
    I would avoid using any metal. Metal can corrode quickly if your chemistry isn't perfect. The better quality plastic valves last nearly forever. Jandy valves are the best, but many of the less expensive brands also hold up reasonably well.
