Thread: Help identify my pressure cleaner
    Nov 2015
    Ok ok
    823
    I can't find any model number on this cleaner. Like most things I inherited when I bought this house concerning the pool, it's in dire Straits of repair. I need to replace the feed hose, the bag, looks like a little flapper check valve that goes below the bag, and it appears the tail end is broken. The feed hose is 15 feet to the reverse valve then another 5 feet to the cleaner for a total of 20 feet. The tail, is 42 inches long and appears to be broken at the end, I have no idea what should be on the end of it or how long it should be. Can anybody tell me the model on this so I can order the correct parts? Also if anybody has any suggestions on where to order porch that would be great. Thanks everybody I appreciate it.
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Nov 2015
    Ok ok
    823
    Re: Help identify my pressure cleaner
    Here is what I believe to be the back up valve, if that helps.
    Qwaxalot's Avatar
    Jun 2012
    439
    It's a Pentair "Legend" pool cleaner. The back-up valve pictured is a "Polaris" unit (works fina as a replacement for the original).
    The tail whip has the end worn off.
    Parts are readily available either on line or at your local pool store.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Nov 2015
    Ok ok
    823
    Thanks for identifying it, I wanted to be sure to order correct parts.
