Results 1 to 17 of 17
Thread: April Showers bring May Flowers?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You know what stinks? I opened my pool almost 2 weeks ago and used the hose to fill up the water level to the skimmer.
    Now, in the last three days we've had torrential rains and my pool is now up to and about to flow over the top rails. I'm soooo frustrated right now, and I still haven't received my water bill.
    I have standing water in my yard, in the corner by the fence there is probably 6 inches of standing water, the ground is absolutely saturated. They are forecasting weather like this for the next week, it may not all be rain but there won't be any sunshine either. I'm starting to feel like I live in Seattle.
    Just a bit po'd right now.
    Mar 2009
    Woods of North Florida
    148
    Re: April Showers bring May Flowers?
    That sucks!
    In an attempt to be optimistic…at least it was rain and not snow?
    And doesn't this little guy make you feel better just watching him?
    I'll leave you alone to go find your happy place...
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    Jan 2009
    Cupertino, CA
    1,966
    I hear you... I drained and refilled in January, then had to drain off another 4-5" from heavy rains in Feb. CYA was too LOW after that.
    --paulr
    BBB "Intermediate Swimmer"
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by frustratedpoolmom
    Believe it or not I am jealous. We sure could use some of that rain down here.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    11,969
    Quote Originally Posted by mdhwoods
    I guess I should learn to count my blessings....
    I'm back in my happy place.
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    I need to up my CYA but everyday the weather man says we are going to get
    up to 4" of rain. So I don't want to have to lose the stabilizer I add and I keep
    waiting. Do we get the 4" of rain? Nope
    Having a pool is always a challenge.
    NW Arkansas
    17,300 IG Gunite pool approx 16 yrs old (here when we bought the house in 2004)
    1.5 HP pump (rebuilt in '06)
    TA60 Tagelus Sand filter (sand replaced in '05)
    no-mas's Avatar
    Jun 2008
    FL
    405
    FPMom,
    Quote Originally Posted by numberonenole
    It does me!!
    Shouldn't we all - everyones biggest problem should be dealing with their pool! Thanks for all the help you provide to so many here!
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    The rain doesn't bother my pool much.. put it sure is makes finishing all of these landscape projects tough!
    2003 Marquis Euphoria - 400gal
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Hey Ann,
    I blew a little water out last night about a half inch, then the water started flowing back toward the pool so I thought i shoud stop...Saturated isn't the word for it. Hasn't rained since noon here yesterday and the ground still squishes...I am going to take more out at lunch time and then more after work...It was over flowing out of the skimmer.
    Beave
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    11,969
    I drained 2 inches. I held the vac hose up to the return and turned on the pump, the other end of the hose out the front thru the fence away from the pool. Took about 10 minutes to drain an inch. Got tired of holding the hose in the 64 degree water with the pressure on the hose, so I turned the pump to low, kept the hose end under water and the syphon action kept draining the water. I managed to wedge the end of the hose into the skimmer to hold it in place while I drained another inch, I walked away for 15 minutes or so and it was just right ... Still standing water in the yard.
    Stupid school district cancelled school. One "suspected" case of Swine flu warrants closing 5 schools and keeping 3,000 kids home? Extending the school year till June 9....we're leaving for Wisonsin on June 5, oh well....
    Jun 2008
    NW MO
    185
    I can totally relate.
    We haul in water for the pool then we have had inches of rain in the last week or 2. My yard sounds swampy as I walk through - especially near the pool - go figure since I have to test water several times each day. My shoes are covered in mud!!
    I drained about a half inch of water out of the pool by backwashing, but it is still nearly overflowing. No wonder I can't get the pool to clear....
    24ft AGP 52in deep ~13,500 gal
    Hayward Sand Filter 250 lbs
    SWG
    1.5 HP pump
    425 gal stand alone QCA Hot Tub 15-20 yrs old
    Jan 2009
    Cupertino, CA
    1,966
    Well, with acid rain maybe you don't need so much MA? Trying to find a bright side...
    --paulr
    Jun 2007
    NC
    255
    ...in the last three days we've had torrential rains and my pool is now up to and about to flow over the top rails.
    At least you didn't pull a bone-headed stunt like I did yesterday. I turned the hose on to fill the dog's water dish before I went to work, then tossed it into the pool ... My wife discovered it at 5PM last night!
    I had to pump over 4" of water out of the pool when I got home @7... Just wait for the water bill... In addition I lost some of the CYA that I put in Monday night.
    The good thing is, and there is always some good thing (right?), that the pool is crystal clear now *and* the filter had a good 30 minute backwash/rinse .
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    I guess we've all had that happen at least once. If not then get prepared cause
    it will happen
    NW Arkansas
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    I feel your frustrations "frustrated". It sounds like yall got what we had here in Houston Monday and Tuesday. I never realized how much havoc can be reaked on a pool when 11 inches dumps on your pool in 4 hours
    But Im glad to hear that you were able to get your pool back in order
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    PVille's Avatar
    May 2009
    Purcellville,VA
    39
    I feel your pain. I opened my pool on April 25th because I know my solar heater can get the water warm enough to swim in a few days. The "plan" was to get the pool ready and then leave the winter cover on during the week and remove it on weekends if it was warn and sunny. We got the pool clean and running in three hours and then water temp went from 56 to 69 in two days of sunshine.
    Mother Nature hates plans...
    We got three weeks of rain and cool weather. Finally took the cover of for good on May 16.
    In ground 15 X 33 10,400 gal. Fiberglass
    Two Returns, Two main drains, One skimmer
    Aqua Logic SWG, Hayward TriStar 1.5HP
    Hayward C3025 (325 sq /ft) Cartirdge Filter
    Solar Heater (Details at http://www.bakerlabs.com/solar)
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    We have just had our most recent frost 2 days ago - we are over a month behind on opening the pool this year. We received 15" of rain since the pool was closed last fall so won't have too much to top it off - I'm hoping we are all just getting the crappy weather out of the way so we can all have an absolutely SUPER summer this year. Last summer tanked and I thought it started well - near freezing nights in JULY last year. No thank you, I'll take the crappy weather now so I can enjoy the rest of the non-snow season here (thats a total of like - 2.5 months? lol )
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
