Thread: Intex Sand Filter/Pump Placement Question
    May 2015
    Wichita KS
    29
    Hello all! This is my first question on this great forum. I've been perusing this site for almost a year now in anticipation of putting my very first pool up! I purchased my pool last summer but am just now getting to the point where I will be able to put it up for the first time, hopefully next month!
    My question is, does anyone know exactly how far up from the bottom of these Intex/Coleman pools the Intake and Return holes are? Here is what I'm thinking of doing and not sure if it will work or not:
    My back yard is sloped, and where I am wanting to put the pump and SWG is 40 feet from the pool. I planned on hard plumbing everything, and burying the pvc, and as I've measured with some twine and a string level, where the pump would sit and where the side of the pool is, the level height is a difference of exactly 3' 6" from the bottom of the pool (the pool sitting lower than the pump 40 feet away). I'm under the impression that these Intex pumps are not self priming, so I'm hoping that if the intake is more than 3' 6" from the bottom of the pool this would work. My pool is still in the box
    If it makes any difference I am also planning on cutting a through-wall skimmer as well.
    Hopefully this makes sense what I'm asking.
    Coleman 18'x48' AGP
    Intex Krystal Clear Sand Filter Pump 2800GPH
    Intex SWG
    **Under Construction** :)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Intex Sand Filter/Pump Placement Question
    Congrats on the pool!
    I don't know what the measurement is but you are correct that the pump is not self priming and that it must be below the water level. But, it doesn't necessarily have to be below the outlet level, just below the water level.
    May 2015
    Wichita KS
    29
    That makes sense! Thanks!
    Coleman 18'x48' AGP
    Intex SWG
    May 2015
    Wichita KS
    29
    Here is a crude drawing of what I was trying to explain
    Coleman 18'x48' AGP
    Intex SWG
