Thread: Stains from a Bobby Pin
    Mar 2012
    Fort Worth, TX
    6
    I have done the Vitamin C test. Crushed vitamin C tablets in a sock and placed it on top of the stain. No luck. Then I bought actual Stain Free Ascorbic Acid and placed a cup in a sock and had it over one stain for 30 min. no luck. It was one Bobby pin that moved around the bottom of the pool and left multiple little stains. I have a 25,000 gallon, pebble plaster pool using BBB method. What do I actually do? I have the pool at 7.2 pH and 0 FC. I'm ready to do the Ascorbic treatment and I know the Bobby pin was metal account I pulled out the min and it was rusted. The stains have been there about a month and a half I'd bet.
    Does it take hard scrubbing to get the stains removed?
    Sorry for the bad pic, but it's very windy right now.
    38,301
    Re: Stains from a Bobby Pin
    I had a similar thing happen in a few spots. I set a vitamin C tablet on one and it disappear almost instantly. The other I set it on for a long time and scrubbed it, but it just faded a little. Not sure why the difference.
    In any case, if putting the Vitamin C directly on the stains do not remove them, then I am pretty sure an AA treatment will not either ... it is the same thing, but more concentrated when you use the tablets directly.
    Mar 2012
    Fort Worth, TX
    6
    So how do you get the stains out, if the Vitamin C doesn't work directly? Jump in and scrub?
    Jul 2015
    Central Valley CA
    1,108
    I have read about people using a squeeze bottle with some MA and a tube such as a piece of PVC to get the acid directly on the spot then with in a few seconds scrub. Be careful and I would use gloves or a brush with a long handle unless you also need an exfoliation.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mar 2012
    Fort Worth, TX
    6
    Quote Originally Posted by atttech-2 View Post
    Interesting, I've read that too, but was hoping for an easy fix. I'll have to give it a try. At least it will be easy to fix pool chemistry if it works.
    Thanks
