Results 1 to 14 of 14
Thread: How Long to Run a Variable Speed Pump
    Mar 2016
    Houston, TX
    4
    Hello Everyone. I'm new to the site here and what brought me here is a debate on how long I should run my pool pump in my new salt water pool in Houston, TX.
    I have a 20'x40' pool, with a model 6060 boster pump controlled by an Omnilogic system and Variable Hayward Century pump. My Pool Builder set scheduled run times which run at variable speeds throughout the day; however, I have spoken with several other pool builders and pool cleaners who say I only need to run the pump 5-8 hours per day. What is everyone's opinion?
    Thanks
    Bryan
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: How Long to Run a Variable Speed Pump
    If that. For many, 3-4 hours is enough. The only thing that is mandatory is getting enough FC in the pool. After that, run time is only for removing debris and sometimes heating, both of which are purely optional.
    Mark
    Mar 2016
    Houston, TX
    4
    Quote Originally Posted by mas985 View Post
    I like that.. The PB said it takes more electricity to stop and start the pump then to run it at low speed all day except when running the cleaner. thank you.
    Oct 2015
    Austin, TX
    83
    Quote Originally Posted by BryanR View Post
    Someone doesn't quite understand... Starting and stopping the pump does take a lot of current but only for a second. It would have a negligible effect on your power bill. So a few on/off high-speed cycles throughout the day isn't going to be any more power than one longer high-speed cycle if the total pump run time is the same.
    However, running at higher speed does take more current than running at low speed - the pump is more efficient at lower speed. So run at high speed for just long enough to get what you need from the chlorinator and cleaner (as MAS985 said) - in a few cycles per day if it makes you happy - and then at low speed to turn over water and get filtration.
    High speed vs low speed is kind of like the difference between driving 80MPH or 50MPH. Low and slow takes less fuel. In a car you drive fast because you've got places to be, but your pool pump is always at the poolside...
    Also be nice to your city utility and don't run your pool pump during peak air conditioning hours (usually 4-6PM).
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Quote Originally Posted by marcgr View Post
    What he said ^
    According to the Pump Affinity Laws, power consumed is proportional to the cube of the pump's speed. So slowing down a pump by a factor of 2 reduces the power consumed by a factor of 8. In other words, run half as fast for twice as long and you will filter the same amount of water, but at roughly 1/4 the power cost. However, running the pump slower will agitate the water less, so maybe less skimmer action will result. You can Google "Pump Affinity Laws" for much more information. Here is a nice article relating directly to swimming pools http://www.nrel.gov/docs/fy12osti/54242.pdf. I realize your question was "how long?" not "VS versus single speed?" but the speed at which you run the pump factors in.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Mar 2016
    Houston, TX
    4
    thank you for the info. i'll check out the article. I have a variable speed pump so I could run it on the lowest speed for most of the time except for when I have the polaris running.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Just for clarification. The pump affinity laws do not take efficiency into account so the power formula is really only relevant for power deliver to the water (aka hydraulic HP). The power consumed by the motor includes this power but also includes power used by the drive electronics, power wasted by heat and power lost to wet end inefficiencies (re-circulation loss and friction loss). So operating at the lowest RPM is not very efficient. In fact, below about 1000 RPM efficiency drops rapidly so you really don't want to operate much below about 900 RPM.
    Mark
    Sep 2013
    Charleston, SC
    537
    I run mine at 1000 RPM most of the time with four scheduled skimming 2500 RPM bursts throughout the day. On those few nights we have a freeze warning, I run the pump at 450 RPM; are you saying I use more overall electricity any time I drop below 900 RPM?
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    mas985's Avatar
    Pleasanton, CA
    11,737
    No, what I am saying is that the pump efficiency drops as measured by gallons pumped per kwh. So basically, as RPM drops below about 1000 RPM, the energy use of the pump levels out while flow rate keeps decreasing. So you don't benefit as much with a lower RPM.
    Mark
    Sep 2013
    Charleston, SC
    537
    OK. In my case efficiency isn't my main priority. Thank you.
    Mar 2016
    Houston, TX
    4
    I dropped to 100% variable speed for 5 hours a day and run my cleaner for 2 of those hours. It has dropped my electricity by roughly 10%.. not a big deal but it's something. I'm sure when it's warm enough and we are using the pool more we increase the cycle time.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Why a 100%? Nothing should require 100% speed. Have you tried other speeds?
    And you really shouldn't need more than 5 hours even with usage.
    Mark
    Sep 2017
    N LAS VEGAS
    1
    My system is similar to yours. At what low speed percentage do you run your pump? For how many hours? My UV has a valve controlling how much water passes through the light. The valve is after the light. The builder had the valve opened about 10%. Should I open the valve 100%? I asked my pool guy and he wasnt sure. Thx for your in put
    CaveDiver86's Avatar
    Jun 2017
    Wellborn, FL
    65
    Recently I have been running 2000rpm for 6hr a day. I'm still tweaking the SWG chlorine sweet spot. I get small bubbles if I run at low rpms like 1250. I also only lose water when the pump running so I don't go for the low and slow method. If I run a solid 24hr I can lose an inch. If I run 6hr I loose 1/4". I must have a leak but none the less that's what I run mine.
    18x36x8 vinyl pool. Pentair Intellaflow, Clean and Clear 150, Intellachlor.
