Thread: opening question..
    Jun 2014
    Rogers, AR
    424
    opening question..
    My pool water was well below the skimmer and upon opening today I discovered it was full of algae.
    I filled the pool yesterday back up to the correct level. I really feel no need for a SLAM as the rest of the pool was fine. I already brushed and vacuumed the pool and everything is looking great.
    Is a SLAM in order or just a really good brushing in the skimmer box all it will need?
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Jun 2014
    15,003
    Re: opening question..
    So you're saying that you only noticed the skimmer full of algae, is that correct? Still, I would prepare to SLAM. If your skimmer was infested with organics, more than likely other dark hiding spots are as well, and they require constant, higher SLAM FC to kill and remove them. The good thing is that if your overall pool looks good, a SLAM shouldn't take quite as long. Not like if your entire pool looked like pea soup. I would clean things up where you can see them, bump-up FC and at least do an OCLT. Compare that with your CC reading. If all is well, then you dodged a SLAM bullet.
    Jun 2014
    Rogers, AR
    424
    Quote Originally Posted by Texas Splash View Post
    Yes the skimmer box was full of algae and crud. The water in the pool itself was substantially lower. My pool was a mess, we had a lot of rain after Christmas and my liner pulled out of the track and floated. I got a lot of ground water in the pool. Surprisingly, I still had CL a whole 2! We have vacuumed and brushed the whole pool twice as well as one have one backwash under out belt for the season and it is only day one
    Thnx,
