Results 1 to 8 of 8
Thread: How do I remove this return jet?
    Aug 2015
    Stevenson Ranch, CA
    10
    Hello. I was wondering if anyone knew how I would remove this return jet (See photo), so I can replace it with a new style. I tried turning it with my hand and it doesn't budge. I've seen posts about using a grip wrench, but there is nothing that the grip wrench would be able to grab onto. The reason I want to replace the jet is because I cannot adjust the direction of the flow. Thank you.
    18.5k gal, IG, plaster, cartridge-Hayward 400, Pentair Intelliflo VS 011810 3HP, Hayward heater, Built 1993, attached spa, Aqua Rite, Jandy iAqualink
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: How do I remove this return jet?
    is that a counter sunk jet? interesting.
    looks like you might be able to get it out with a thin wall socket of a large size.
    just make sure it fits without play and very slowly back it out to avoid breakage.
    Dolphin E10 Cleaning Robot.
    Aug 2015
    Stevenson Ranch, CA
    10
    Yeah. It's countersunk. I just bought the house. What do you mean by wall socket? Thanks.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    socket wrench.
    Aug 2015
    Stevenson Ranch, CA
    10
    Thanks for your input. I'll try that.
    Jan 2015
    las vegas
    92
    Use needle nose pliers, spread them apart and place ends against the inside edge of the tabs and turn left. The female adapter in standard 1.5 in so you can switch to different type of return fitting if you want
    Aug 2015
    Stevenson Ranch, CA
    10
    Thank you lasvegaspools!
    Jan 2012
    340
    Looks like a remodel fitting. Not sure if you're going to be able to find anything else that works for you.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
