Thread: Question on Pool Fittings on Tahoe Blue Pebble Pool Interior
    Feb 2016
    McKinney/tx
    36
    We are going with a Tahoe Blue pebble interior for our pool and I believe we could choose from white or black. Our salesperson said that black would look best but I am wondering if we should request white or grey instead. Does anyone have any pictures of fittings in this color pool or recommendations?
    Build in-progress, broke ground 3/16/2016, My Pool Build
    18x25 freeform IG gunite (13k gallons); waterfall, weeping boulders, rock wall spa w/ 8 jets
    Oklahoma Flagstone coping, Tahoe Blue mini pebbles
    Jandy Equipment (DE filter,var speed pump, JXi heater, Remote Automation;
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Question on Pool Fittings on Tahoe Blue Pebble Pool Interior
    I think gray would be best, black would probably be my second choice. ,
    Here is a gray one for 2 bucks if they aren't cooperative.
    Eyeball Fitting 3/4 Opening Gray | Hayward SP1419DGR | Sunplay.com
    Dec 2014
    Houston, Texas
    134
    There're two tones of gray! We use dark gray on Tahoe blue although light gray will work too.
    Mar 2014
    Angleton, Tx
    91
    We have black fittings on Blue surf plaster. I think it looks really good.
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
