Results 1 to 7 of 7
Thread: Re: Curious about simple automation of pump
    Mar 2016
    Orlando/FL
    3
    Hi all, I am new here and need your expertise.
    I am also trying to automate my pool pump. My automation is based on Wink. My pump is controlled by a mechanical clock which doesn't work, and a light switch that controls the circuit. The pump is 115v, 1.25hp, 14.87Amps. Is there a device that will allow me to set on/off times? I also have an in ground hot tub, but that will be a later project.
    Thanks in advance.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Welcome to the forum!
    A mechanical timer is generally used to control on and off time for pumps. It sounds like you have one but broken. Depending on the brand, you may be able replace the internal components.
    Intermatic are the most common timers: Intermatic T104 208-277-Volt DPST 24 Hour Mechanical Time Switch - Intermatic Timer - Amazon.com
    But it wasn't clear to me if you wanted the timer to be Wink compatible. Something like this may work: 220V / 240V 30 AMP Insteon Load Controller Normally Open Relay (Dual-Band)
    Mark
    Mar 2016
    Orlando/FL
    3
    Quote Originally Posted by mas985 View Post
    Thank you. Because of conditions around my pool and home I need to be able to control the pump when away from home. The mechanical time won't allow that.
    Does the part you mentioned come in 115v?
    Apr 2013
    Sacramento, CA
    2,769
    I don't believe the relay described by Mark comes in a 110 version.
    You could use something like this:
    SwitchLinc On/Off - Insteon Remote Control Switch (Dual-Band), White
    3 caviets:
    1. Its Insteon so until you hook it up and it works compatibility with your application is difficult to determine.
    2. Its really only rated at 15 amps. So how many amps does your pump pull? It needs to be on a 15 amp breaker.
    3. Its Insteon. They can be temperamental and subject to heat. So if you run it hot or in a hot location they tend to have a high failure rate.
    May 2015
    Denver, NC
    6
    You could almost use the Linear zwave Relay. It specs 20A and separately mentions 1HP motors.
    I used the Intermatic CA3750 with Smartthings for my 1HP 220V pump.
    Mar 2016
    Orlando/FL
    3
    Thanks for the advice. It is on a 15 amp breaker and the pump clearly says 14.87 amps. Is it the hp or the amps that makes the difference?
    May 2015
    Denver, NC
    6
    Disclaimer: I am not an electrician.
    The Amps matter - they heat the wires, hence the breakers are in Amps.
    The HP is loosely related to the current the motor draws in operation and at startup.
    The motor current and the breaker amperage (changeable) are your constraints.
    You can call or email Linear & discuss it with them or talk to an electrician. (In my experience, home automation & LED lighting freak out electricians - they can't answer simple questions in this context)
    Good Luck!
