Results 1 to 18 of 18
Thread: PH Numbers
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    PH Numbers
    My pool was put in late last year (First week of Sept). My PH was 7.8 and a little higher and I kept adding MA to bring it down. So far this year since I opened last week it was 7.5, but has dropped to 7.2 and staying there. Is this OK?
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: PH Numbers
    Yes. 7.2 is okay for swimming, and since your pool is vinyl, you don't need to worry about plaster etching.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: PH Numbers
    Any rhyme or reason as of why it may be down to start the year, Richard?
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: PH Numbers
    Give us some test results. Also test the PH of your fill water.
    Richard320's Avatar
    Jan 2010
    19,075
    Re: PH Numbers
    Quote Originally Posted by kywildcats View Post
    Low TA caused by a whole lot of rain or snow dilution? Did you use pucks over the winter? What are the rest of your test results?
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: PH Numbers
    I will post a full set of numbers shortly. I am waiting for my sample water to come up to room temp before checking CYA. Thanks!!
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: PH Numbers
    Here are the numbers for today.
    FC: 7
    CC: 0
    PH: 7.2
    CH: 100
    TA: 70
    CYA: 60 (Slowly making it rise to 70)
    Water temp: 60 (Water sample was brought in house for 3 hours before testing)
    Yesterday FC was at 6. I turned on SWG to 15% and ran the pump for about 4-6 hours, and it raised it to 7
    Water is crystal clear!!
    No Pucks used over the winter
    PH just barely changes color from my well water. Less than 6.8 for sure
    Mark
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: PH Numbers
    my ph tends to drift down if it isn't at TA of 80 or slightly higher.
    I have vinyl and about the same volume pool as you, try adding 2 lbs of baking soda, then test ta & ph.
    get the ph up to 7.5/7.6 with mule team borax or soda ash (shouldn't take much, maybe a cup). should hold ph steady then.
    Dolphin E10 Cleaning Robot.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: PH Numbers
    Quote Originally Posted by borjis View Post
    Use both the baking soda and borax? Can they just be broadcast into the pool water?
    Mark
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: PH Numbers
    whaaaa? I should be doing this, too?
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: PH Numbers
    Quote Originally Posted by Helen203 View Post
    This is what I was told to do when checking CYA numbers. I can't tell you about the other numbers, but somebody will chime in shortly I'm sure!
    Mark
    Richard320's Avatar
    Jan 2010
    19,075
    Re: PH Numbers
    Yes, the CYA test doesn't work well when the water sample is really cold. Let it warm up to 70 or better before testing.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: PH Numbers
    So the good news is, I only added half of the stabilizer the calculator told me to add, in a sock, in the skimmer.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: PH Numbers
    Richard, do all other test do ok with colder water temps??
    Mark
    Richard320's Avatar
    Jan 2010
    19,075
    Re: PH Numbers
    As far as I know.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: PH Numbers
    OK thanks! What did you think of my test results from today?
    Mark
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: PH Numbers
    Get a 1 gallon bucket, fill with pool water, get a stir stick, pour ALL the baking soda in while you stir it around.
    slowly pour into the pool deep end about 1 foot away from the return jet. (while pump is running)
    rinse out bucket
    do the borax or soda ash same way.
    Keep the pump running for an hour then test. ph & TA
    DFW, TX
    24,517
    Re: PH Numbers
    Here is a handy page from Pool School about chemicals, what they do and how to add them. Pool School - Recommended Pool Chemicals
