Thread: Skimmer has 2 ports, one plugged Also need manual vac to replace dead Kreepy
    Mar 2016
    Tucson
    6
    I appear to have zero draw into the main drain. When I brush fine dust over it I see nothing going that way. Background: This pool was built in 1977 by Patio Pools with the turbo heads in the floor that never worked well. At some point my family added a Kreepy Kraully with the skimmer attachment. Would someone have capped one of the skimmer ports to increase suction?
    Also, I have taped the current Kreepy together for the last few years and it's ready for the trash. I'm happy to put it there as I'm tired of kicking it when I'm trying to swim. What's the best manual device for vacuuming the bottom? I see things that use a garden hose and others that I assume I'd have to use a skimmer attachment for. Yes cost is important so any advice would be appreciated.
    David
    Pool - IG Oval 15500 gallon gunite/plaster built 1977
    Single speed ?HP pump, Triton II TR-60 sand filter
    TF-100 Test Kit just purchased
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Skimmer has 2 ports, one plugged Also need manual vac to replace dead Kreepy
    If the hole in the skimmer closest to the pool is plugged then that means that your bottom drain is not plumbed to the skimmer. Which should also mean that there is a valve in front of the pump to switch from drain to skimmer. Even with my skimmers off and all suction from the drain there is still not a lot suction there. Sometimes I have to brush dust over the drain a couple of times to get it to go.
    But, who knows how they did things in 1977? I have weird plumbing issues in my 1975 house right now because of how they did it back then.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,945
    My previous pool was a 70's vintage and a previous owner had plugged the main drain and the second opening in the skimmer that goes to the main drain, due to a leak in the pipe between the skimmer and main drain. I didn't figure it out until I removed the drain cover and found that the pipe had been plugged at both ends.
    chiefwej
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    It very well could be that the main drain line in bottom of skimmer was plugged to increase suction from the skimmer.
    Divin Dave,
