Results 1 to 12 of 12
Thread: Need A Clorox Bottle Holder - Calling All PVC Engineers
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Okay it is hard for me to lean down, which impedes me from adding bleach to my pool as regularly as I want. We need a Clorox bottle holder that makes it easier for adding bleach, for those that need it. I am thinking a (contraption?) device made out of PVC, since PVC is so easy to work with, and available, and is already present in our pools. I believe the goal is to add bleach slowly, with no splashes or spills. I would love to see what you have come up with, or can come up with. I am an engineer also, but not mechanical, and certainly not PVC. I will work on this also.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    38,415
    Re: Need A Clorox Bottle Holder - Calling All PVC Engineers
    Sounds like it is time to automate your chlorine addition with a peristaltic pump or SWG
    I am just afraid that trying to pour bleach while standing greatly increases the odds of something going wrong.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    no I will be sitting
    The cholridator or liquidator or whatever its called intrigues me, but no more room on my pad. And thinking just easier to add directly with the right tool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Do you have a ladder, where you could just cable-tie a funnel with some vinyl tuning to it?
    OR
    Find a threaded adaptor that fits through one of the holes in your skimmer lid. Insert it, then screw a threaded coupling underneath to secure it. Glue a length of pipe in and you have a nice long handle to lift the skimmer lid with as well as a place to set the funnel while you're pouring bleach.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    well I read here adding bleach to skimmer is not preferred, but yes, you are on right track
    Richard320's Avatar
    Jan 2010
    19,046
    Quote Originally Posted by MarkTX View Post
    It's not preferred, but you what you must.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    I really just want a (bionic?) arm extension so I can sit in my chair and pour in the jug slowly, away from the walls/plaster in the deep end.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Ok i am am going to withdraw the question, I just added a gal of bleach and it was not that hard for me. Seems I am getting stronger, or more limber. But the old timers may still need our help. Just sayin.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You mention that you are getting stronger and more limber, are you recovering from some type of injury?
    Aug 2014
    Northern IL
    4,615
    You go!!! I have a bad back too, and sometimes it's a matter of "use it or lose it". Consider it exercise!!!
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Quote Originally Posted by Isaac-1 View Post
    Yes, the used-up-all-my-cartilage-playing-football-and-tennis injury. it sucks. but that is one of the reasons I wanted a pool. the olympic swimmers seem to be in good shape.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,575
    I like the funnel idea Richard posted. I bet that would work the best and be easy to find.
    Kim
