Results 1 to 11 of 11
Thread: Hello, I'm about ready to fill in my pool (with dirt)....
    Mar 2016
    carriere, MS
    3
    Hi everyone,
    My name is Justin. I am new to pool care, just dropped a bunch money on a new liner for my in ground pool. It's not going well, but I will read pool school before going into it.
    Best Regards,
    Justin
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hello, I'm about ready to fill in my pool (with dirt)....
    Hi Justin,
    Welcome to TFP! Why don't you start a new thread in the Just getting started forum, and let us know where we might start to help you out? There will be plenty of folks more than willing to jump in and see what they can do. Let us know how we can help.
    Good to have you with us, and glad you came!
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Welcome!
    You don;t really want to fill it in -- that's expensive! One cubic yard of fill dirt is only 202 gallons.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Justin,
    Man don't fill it in! It's easy to learn how to maintain it and it's cheap too! Pools are a great way to end a day of busting out a couple of 20 point 8 ways or making that big-way multi-plane formation at sunset (or having to hitch a ride because of a bad spot!). It don't get any better than a pool at the end of the day.
    Start in Pool School with the ABC's.. not much to it really. Easy Stuff!
    Good Luck
    DivinDave
    USPA, D-17203
    Divin Dave,
    Mar 2016
    carriere, MS
    3
    Yeah, I'm draining (half) my pool now my CYA was 180 and chlorine 0. Shocked it and it turned green! So I am starting over pretty much and not trusting my pool store. They tried selling me 60lbs of calcium that I "needed" last week. I didn't buy it and instead just put about a bucket full that I already had. This week when they tested, surprise my calcium is fine.
    Where do you jump Dave?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That sounds like you've got some metals in your water if it didn't turn green until you elevated the Chlorine level.
    Essential Links:
    38,433
    Welcome to TFP!!!
    Please add your pool details to your signature as described HERE as it will help us help you.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Such a shame you had to get a new liner than drain again....and you don't need to worry about calcium in vinyl pool.
    Don't even think of filling that pool in with dirt!! Let us help you get yourself organized and on track and you'll see how easy and cheap it can be to manage.
    Yippee
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey Justin,
    I've moved your thread here to JGS since we've moved past introductions with it.
    Essential Links:
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Quote Originally Posted by YippeeSkippy View Post
    Unless he has a heater...then he needs to maintain a minimum of 225 ppm of calcium (in most cases).
    Dolphin E10 Cleaning Robot.
    38,433
    Quote Originally Posted by borjis View Post
    This makes absolutely no sense to me. Why would the calcium level impact the metal in the heater? Really the most important thing is to keep the pH in check, if that gets too low it will certainly damage the heater.
