Results 1 to 7 of 7
Thread: Price of MA (muratic acid)
    Apr 2009
    South of Houston, Texas
    18
    Just curious.......what is everyone paying for a gallon of muratic acid. My pool store of all places seems to be the cheapest but they are still going up and now at $4.60 per gallon (18.00 per case of 4). Is Muratic acid the least expensive way to bring down PH. I have always needed to add MA every few days to bring my PH down, I never seem to have to raise it. Lowe's is $6.00 per gallon, hardware store is over 6, etc. I just want to make sure that everyone uses MA for ph reduction.
    IG pool gunite/Plaster, 33 x 20, 20000 gal., 4.5ft-5-3.5ft, Triton FNSP-36 DE filter 36sqft 90gpm 43200 in 8 hrs, WhisperFlo Triton 1.5HP, Polaris 280 with booster pump, and a Dog that loves to swim,South of Houston.
    Feb 2008
    Denton, TX
    5,061
    Re: Price of MA (muratic acid)
    Last time I bought some, it was about $9 and some change for two 1-gallon jugs of it. I have only seen it offered in boxes containing the 2 1-gallon bottles.
    It's what I use to lower pH as well. I add about 9 oz. of it to my pool every 4 days or so as long as the pool temp is above 60 degrees. When it cools off, I don't need it as much.
    no-mas's Avatar
    Jun 2008
    FL
    405
    I buy 31.5% MA at Ace Hardware - but the price just increased last week to $4.99 from $4.39.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I'm paying $6.95 per gallon of 31.5% MA at Lowes.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Muriatic acid comes in a variety of strengths so it is a good idea to check what you are getting. Some of the stores recently changed to 14% MA but kept the prices the same.
    Mark
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I'm about the same at 4.50/gal for 31.5%. the worst for me is chlorine (2.5 gallon refills) at $4.25, up from $2.49 in 2006. I've been hoping the prices would start coming down but it doesn't look like they are.
    Apr 2009
    Orange Park, FL
    104
    Quote Originally Posted by jmas65
    It's on sale this week at our Ace Hdwe, 3/$10.
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
