Results 1 to 8 of 8
Thread: How much Clorex
    Mar 2016
    San Carlos, Sonora, MX
    3
    How much Clorex
    My stats are in my signature. With Free Chlorine at 1 and chlorine at .5, how much Clorex should I add?
    7,180 Gal, In Ground, Hydrazzo Finish, Hayward Sand Filter w/ Vari-Flo XL Valve, ESPA 1 HP pump.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: How much Clorex
    Here ya go! This will do all of the work for you!
    http://www.troublefreepool.com/calc.html
    You also need a good test kit. How are you testing the water now?
    Kim
    Jun 2014
    15,145
    Re: How much Clorex
    SBT, welcome to TFP. We can help you with question, but need to know your CYA level. That's going to drive where your FC should be as noted on the Chlorine/CYA Chart (link in my signature). But I can say for sure, even without knowing your exact CYA level, it's low. Very low. Can you post a full set of results?
    Also might be good to review Pool School - ABCs of Pool Water Chemistry so all of this makes sense. Nice to have you with us.
    Mar 2016
    3
    Re: How much Clorex
    Thanks you guys. I have tried the calculator a couple of times and cnat seem to get it to work. I also do not know what CYA is.
    Right now I'm just using a kit that tests only for Chlorine and PH along with test strips. I'll get a full kit upon a visit to the US next week. In the meantime, my numbers are:
    TA: 120
    PH: 7.2
    Free Chlorine: 2
    Total Chlorine: .5
    Total Hardness: 500
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: How much Clorex
    Welcome to TFP!
    Here is a tutorial on how to use Poolmath, Pool School - PoolMath
    Mar 2016
    3
    Re: How much Clorex
    Thanks for the tutorial. I have read it and tried again, but nothing happens when I click on Calculate.
    Jun 2014
    15,145
    Re: How much Clorex
    SBT, when you go to the Poolmath calculator , you'll see two columns (NOW & TARGET), so you'll enter your numbers into each row as applicable. When you do, look to the right of each row and you'll see an explanation. It's a "busy" chart and can seem overwhelming at first. Just take time with it for now and experiment. Make sure you enter you pool volume in gallons at the top, and enter (type) the type percentage of bleach you are using. As you move the mouse curser over each item to the right, it will give an explanation at the top. Hopefully that will help you.
    These 3 links are VERY important as well:
    Pool School - Chlorine / CYA Chart
    38,292
    Re: How much Clorex
    Welcome to TFP!!!
    I would suggest that this is the most important thing for you to read:
    ABCs of Water Chemistry
