Thread: Bonding Question
    Tom Tank's Avatar
    Aug 2014
    Fuquay Varina, NC
    31
    Bonding Question
    Never had an issue before and now start to feel a little tingling on my hand when my Polaris Booster Pump is on and my hand is on the pavers around the pool. Nothing has changed except that I moved some pool furniture around. Does aluminum pool furniture need to be bonded somehow? Also, where should the copper wire end? Should it be a continuous loop around pool? My wire ends connected to an old gas pipe where a heater used to be. Is that normal? Thanks, Tom
    22,200 gal, IG Vinyl 3.5' - 8.5', Haywood s240 Sand Filter, Polaris 180
    manually chlorinate, 2 skimmers - 1 main drain - 3 returns plus waterfall feature
    TF-100 test kit, pool in sun ~10am - 5pm
    22,548
    Re: Bonding Question
    It should be a continuous loop with pigtails to each piece of equipment. Furniture usually isn't bonded, but all the other metal parts and all electrical equipment should be.
    Apr 2013
    Sacramento, CA
    2,769
    How old is your pool?
    The wire should run completely around the pool and be connected with clamps to the pool rebar. Some of this may be imbeded in the pool structure and you can't see it. There should be a metal grid around your pool under the pavers 3 feet out from the pool. If you are further than 3 feet your bonding may be correct but you still have a current leak.
    So You have a current leak most likely the booster pump. Some connection may be compromised and you don't know it.
    With bonding its usually best to call an electrician and see if they can figure out what is wrong.
    Tom Tank's Avatar
    Aug 2014
    Fuquay Varina, NC
    31
    Pool is about 15 years old. Why do you think they would bond everything and not run the wire in a loop back to the pump? When I shut off the booster pump there is no tingling sensation at all. However, the booster pump is bonded.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I suspect you have a problem with your booster pump or its wiring, and I would stop using it immediately until you can find a problem or an electrician can figure it out
    Your bonding system isn't complete. Bonding connects everything that is conductive together electrically so everything is at the same voltage.
    With a complete bonding system, if something like a loose wire or some kind of failure like a toaster falling in the pool were to happen, you wouldn't get shocked.
    Since you are being shocked, it's pretty clear your pavers aren't bonded. Brings up a problem with pavers in that they are difficult to bond. About the only way you can do it is with a copper mesh under the pavers.
    Your bonding system should be hiding the problem that seems to be coming from your booster pump.
    Apr 2013
    Sacramento, CA
    2,769
    I suspect that your booster pump is somehow leaking current and needs to be shutdown. It may be bonded but the pavers are not.
    I agree with John above.
    At the time your pool was built many jurisdictions did not require bonding under pavers
