Thread: How to repair cracks between coping and between waterline tiles
    Jul 2012
    Katy, TX
    10
    I have flagstone coping and the grout is cracking. Also the material that was used to fill the gap between the coping and decking needs to be redone. There are also hairline cracks along side some of my waterline tile. Are these things I can easily repair or do I need to find a professional. If it is a DIY project can anyone suggest products I should use.
    24,215 gallon, 520 pentair cartridge filter, IG, pebble, Pentair Intelliflo variable speed 3 HP for filter pump, Pentair WhisperFlo 3/4 HP for waterfall, booster pump for cleaner, hot tub with overflow into pool, finished Sept. 2011, Katy, TX
    30,431
    Re: How to repair cracks between coping and between waterline tiles
    If you have little or no experience with masonry (tile, cement, etc), I suggest you let a pro do it. It sounds like some of the coping may have to be removed and reset. That's a lot of heavy lifting and grinding.
