Thread: Possbile Scale
    Mar 2016
    Ponce de Leon, Fl
    6
    Possbile Scale
    So I neglected my pool this winter and now I am seeing hard white stains mostly on the bottom of the pool They are raised as when I run a pool net over them, it is rough and you can feel it get stuck on some of the larger ones.
    I did add 3 lbs of ascorbic acid as well as 10 lbs of Suncoast Stop Stains. I can't tell that this had much change on the hard spots.
    Can someone please confirm from pictures if this is indeed scale and the needed course of treatment. The first two images are from the bottom in the shallow/deep. The last photo you can see more clearly as it is a photo from the shallow swim out.
    Jun 2014
    15,189
    Re: Possbile Scale
    Hello and welcome to TFP! Is it scale? Perhaps, although those are some unusual shapes to me, and the color a bit dark in one photo. It would be best if you could post a full set of water test results for us to best evaluate your situation. Could you post:
    FC
    CC
    CYA
    pH
    TA
    CH
    We may have an additional question or two once we receive those results.
    30,426
    Re: Possbile Scale
    Good advise from Texas Splash. I agree that those buildups are pretty unusual looking but still may be calcium scale. Posting those test results may give us some further clues.
    Jul 2011
    Arizona & California
    805
    Re: Possbile Scale
    See this thread about the cause of calcium nodules. Calcium Nodules in Pools
    Jun 2014
    15,189
    Re: Possbile Scale
    That's a very interesting read. And the two inserted thread links provide pretty good examples. Thanks for pointing that out to us OB.
