Results 1 to 7 of 7
Thread: 2 stupid questions about adding CYA
    May 2015
    Chattanooga
    18
    so my first week with my test kit has been interesting.....
    FC 7.5
    CC .5
    PH 7.7
    TA 150
    CH 50
    CYA 40
    pool store had tested my CYA a week ago and found 60, but i tested 3 times and twice it was exactly 40, and water temp was in the high 60's. so i'm assuming pool store was wrong, which seems to be typical around here.
    so, i started with adding 34 oz of 96% pure CYA stabilizer granules yesterday. if my math is right, that should put me around CYA 55. it would also prove my pool volume is accurate. so my 2 stupid questions:
    - when they say wait a week to test again, can i go ahead and test again if the sock is empty? (i dumped it in a sock in the skimmer)
    - and by sock i literally mean athletic sock, so let me know if that was wrong
    thanks, as always!
    17k g IG vinyl pool, hayward c3030 cart filter (325 sqft), hayward tristar 3207ee 3/4 HP pump, pentair intellichlor IC20 SWG, aquacomfort act1100 heat pump
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: 2 stupid questions about adding CYA
    It takes up to a week, so it could in theory show up any day this week, but IMHO you'll just be wasting test chems. I was just assume it was there until next Sunday and test then.
    Yep, an athletic sock!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mar 2015
    South Texas
    411
    You can test again but with the granules it usually takes about a week to show up on the CYA test. You did it correctly by using an athletic sock but next time instead of putting it in the skimmer, hang the sock in front of a return with a weight of some kind on the pool deck to hold the sock in place. Then squeeze the sock every few minutes or so until all of the CYA is gone.
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm just going to cover your stabilizer question for now.
    I'll say first to test on your own, and trust your results. Your sock is fine. So, after the stuff in the sock is completely gone assume that it's there, but give a few days before you test again. Wait until a week is passed and you've retested before deciding you need to add more. This is being over cautious, but it won't hurt, and you'll be dead certain for sure. The one week window is something we are talking about behind the scenes right now, but follow that for now, and you'll have no problems.
    Essential Links:
    May 2015
    Chattanooga
    18
    Thanks everyone, i will be patient!
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    Quote Originally Posted by Patrick_B View Post
    Just as a data point since y'all are discussing it behind the scenes, my personal experience has been it only takes 24-48 hours, with the pump running continuously, for CYA to show up on the test. After that my CYA test results show no additional rise. I don't know if it's the brand of granuals I use or the fact that I run the pump continuously when adding CYA that contributes to my experience.
    Still, like was mentioned, there's no harm in waiting a week, and waiting assures an accurate result.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Thanks for that feedback.
    And there are no stupid questions!
