Thread: Do I need a better pump
    Apr 2009
    Los Angeles, Ca
    11
    Hello I have been reading this site non stop for 4 days it has so much good info.
    Last year I had an 18' round intex with a 1500 gph filter pump and intex salt chlorinator that was great so this year
    I decided to go bigger.
    My question is the 3/4hp 4000gph pump from intex strong enough. This is what I have planned. Pump to salt chlorinator to Solar panels that I will place on roof( quanitity and brand still undecided but leaning toward solar bear because of 2" header) I will have a leaf skimmer and hopefully an automatic vacuum attached also. I have not set anything up yet but am I doing to much.
    thanks
    INTEX ULTRA FRAME RECTANGULAR POOL SET, 32' x 16' x 52", Water Capacity (90%): 14,364 Gallons
    Intex Easy Set 4000 gph Filter Pump, 110~120 Volts - 3/4 HP , Hayward c751 star clear filter.
    Apr 2009
    Toronto, Canada
    33
    Re: Do I need a better pump
    From what I understand, it all depends on how long you want to run your pump. Also, you need to know your total head to know exactly what real gpm/gph your pump is able to produce. 4000 gph is probably "best case scenario" so I would not count on it.
    I would say with your pool size 3/4 Hp is more that enougth - you will get 4 hour turnover time for sure, so all you need is to run it 4 - 8 hour per day.
    Igor.
    16K gallons Vinyl Inground with spill-over spa. 1.5 hp Pentair UltraFlow, 26" Pentair Meteor sand filter, Raypak Gas heater.
    mas985's Avatar
    Pleasanton, CA
    11,741
    The maximum head of the pump must be greater than the height of the solar in order to prime the solar. The Intex pumps tend to have low head so I'm not sure it would work properly but you need to check the head curve of the pump.
    Mark
