Shieldsfx said:Richard,
I don't think there is much more to do here, except for me to turn up the flow rate. I am curious if anyone else has similar conditions to confirm my theory or duplicate this situation?
I do indeed appreciate your help here and welcome further feedback or questions.
Fran
I recently had a new liner and a Hayward/Goldline Aquarite XL installed. Over the weekend I was working on my water and just yesterday I got my water balanced and noticed my free chlorine had gotten up to about 6.1PPM so I turned the generator off. Up to this point everything has been working perfectly. I did two things different last night, I added 8oz of algaecide and 4 oz of clarifier last night with the SWG OFF and ran the filter most of the evening. This morning I woke up to crystal clear water.
I turned on the equipment and decided I would set the SWG to auto and set it to just 20% to see what happens. I was told the SWG will eventually stop generating when the chlorine levels reach a certain number and wanted to verify this. Shortly after turning on the SWG I noticed the same effect in your picture, a milky white cloud coming from my four return jets.
I turned the SWG off and the milky white effect stops. I thought there might just have been something sticking to the plates casing this so I turned it back on. Same problem for about five minutes then I turned it off. After about 10 minutes the cloud dissipates with the SWG off.
The only thing different from yesterday has been the algaecide and clarifier. I put in just enough of each as per the directions on the bottles and filtered the water with the SWG off for a good six hours.
I left everything but the SWG on when I left to see if just letting the water filter and run over the cell while off for another eight hours will make it stop.
I'm thinking the culprit is most likely the algaecide. You mentioned Hayward reported this. I did but some inexpensive algaecide from SAM’s club and perhaps I will need to find something that is formulated a bit differently that won’t mess with the SW?
I’ll experiment with it and research it a bit more.
By the way I’m very surprised at just how well the SWG works. My pool is about 24,000 gallons and free chlorine has jumped up to very high levels very quickly. I did not turn it on until I had about 3200 PPM of salt and my PH and AL where within proper ranges. I’m pretty happy with it so far... just need to figure out the cloudy white mystery.
